Hi, I'm trying to convert .srt subtitles to .ssa. I've edited them in Subtitle Creator, and some of the lines have only a few words italic and the rest regular. When I opened the subtitles in Subtitle Workshop it showed the whole lines as italic.
I was wondering if there is a way to make only a part of the line italic in Subtitle Workshop.
I've also tried converting the subtitles to .ssa first and then editing the italic parts in Sub Station Alpha. But since my subtitles are in croatian, Sub Station Alpha doesn't show the non-english letters correctly.
So, if you know a way to make only a part of the line italic in Subtitle Workshop, or you know how to make croatian characters show correctly, or you know a different way to convert .srt subtitles to .ssa while maintaining the original formatting please help
Nope, there's the same problem with some characters as in Sub Station AlphaOriginally Posted by Midzuki
In this case, open your .srt/.ssa in Notepad or Wordpad,
then save as Unicode-text. Don't forget to set the "Encoding" flag
of your .ssa files to "1" and the "codepage" flag of DirectVobSub to "DEFAULT".
HTH. -
Thanks, this works, but only for Aegisub and not for Sub Station Alpha.Originally Posted by Midzuki
But, I've found an even simpler method. I use the Open subtitles with charset... option in Aegisub, and set the charset as local, I use the same option when exporting to .ssa
Convert pac subtitle to something that I can open in Subtitle workshop
By Tiger_1982 in forum SubtitleReplies: 11Last Post: 15th Aug 2015, 21:49 -
Subtitle Workshop - not creating subtitle at current time location
By botjocrow in forum SubtitleReplies: 0Last Post: 14th May 2011, 04:09 -
how to open chinese subtitle in subtitle workshop
By pcb in forum SubtitleReplies: 2Last Post: 28th Nov 2010, 17:03 -
Subtitle Workshop 4 crashes when loading subtitle file
By Batou in forum SubtitleReplies: 0Last Post: 26th Mar 2009, 07:57 -
Problem expanding subtitle time with Subtitle Workshop
By Kaze105 in forum SubtitleReplies: 1Last Post: 11th Nov 2008, 23:16
