i have got mp3 files with low bitrate( 64kpbs) i want to increase the bitrate so that the quality will be much better. how can i do that? thanks
Just because you re-encode to a higher bitrate does not mean it will make it better quality
MP3 is a LOSSY format, it is compressed by discarding information, once it is gone, it is gone, you can never get it back.
Increasing bitrate will only make the file larger, not any better. -
If you have the original source, you can encode an mp3 with a higher bitrate the first time around.
Yes there is no point in upcoding a mp3. You will not gain anything. You can't make something from nothing (there isn't an audio equivalent of upscaling like dvd upscaling as far as I know). Your only real option is to use the original source and create a higher bitrate file from the original.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
some audio players don't accept lower bitrate files. that is why asked for enhancing the bitrate. thanks
Find a genie in a bottle and rub him/her the right way.Originally Posted by sumeshkri
If that's all you want, use any of these audio tools:Originally Posted by sumeshkri
LameXP
BeSweet
MediaCoder
See https://www.videohelp.com/tools/sections/audio-encoders for more.
As others have noted, you can't improve the quality though. -
Hmmmmmm... A p0rn post!Originally Posted by stantheman1976
Reported.
How to increase the bitrate of a video by avisynth ?
By avengerevenge in forum EditingReplies: 31Last Post: 11th May 2013, 01:13 -
How we can increase audio of a video file when we burn it on dvd
By nusratjaveid in forum DVD RippingReplies: 2Last Post: 5th Dec 2010, 23:35 -
Increase the bitrate---> Lose Quality?
By mark63534 in forum Newbie / General discussionsReplies: 10Last Post: 21st Jul 2010, 14:36 -
Trying to find a program I once had to increase volume on a audio file
By natty in forum Newbie / General discussionsReplies: 6Last Post: 18th Jul 2007, 15:57 -
Saving XviD Video in Vegas.. MP3 Audio Bitrate?
By Kargo in forum EditingReplies: 2Last Post: 5th Jul 2007, 08:26
