I'm sure this question has been asked and answered, but I couldn't find anything specific to what I'm looking for that is current. Here I go:
I am planning on converting old 8mm to DV using camcorder and projector, then further transferring the video onto my pc for editing and ultimately burning to DVDs. I also have many VHS tapes that I plan on converting into digital format. My CPU is up to the task (specification wise), but there are many choices and I'm looking for something under $300. I software I already have is Adobe Premeire, I believe that is more than sufficient for what I'm looking to do.
Can anyonepoint me in the direction of recommendations/reviews. Thank you in advance for any help....
Closed Thread
Please don't cross post. One topic is enough. https://forum.videohelp.com/topic348167.html
Capturing 8mm and Super8 film to hard drive
By coldd in forum Capturing and VCRReplies: 3Last Post: 15th Jun 2011, 20:37 -
Problems with my VHS/8mm/MiniDV to DVD project
By compgl in forum Capturing and VCRReplies: 6Last Post: 15th Jan 2010, 10:30 -
8mm to Digital - Capturing w/ DV Camcorder
By tripecac in forum Capturing and VCRReplies: 61Last Post: 9th Jul 2008, 19:51 -
Capture 8mm/VHS > DV, recommendations for hardware
By nutshellml in forum Capturing and VCRReplies: 4Last Post: 21st Mar 2008, 22:07 -
Newbie needs advice - transferring 8mm(camcorder) tapes to DVD
By KitKatluvr2 in forum MediaReplies: 4Last Post: 18th Jun 2007, 23:51
