If I am editing and converting a DVD video from footage captured by my TV tuner card for playback on DVD players (on PAL system equipment) what would be the pixel aspect ratio i should choose when asked by the editing software or titling software (i prepare tiltes on a seperate software and inport to the NLE software) before final rendering ?
When does one choose 1:1 and when does one choose !:09? PAR
	What resolution are you capturing at from your tuner card ?
 If you capture at standard 4:3 or 16:9 resolutions then you should not have to alter the pixel aspect ratio, or even select it when you edit. You should just be able to choose a standard PAL 4:3 or PAL 16:9 Aspect Ratio and begin editing. Unless you captured at something like 640 x 480, you should not need to use 1:1 for broadcast to DVD processing.Read my blog here.
	Hope this will help some
 http://en.wikipedia.org/wiki/Pixel_aspect_ratio
 There is more to read if you type "Pixel aspect ratio" in your search engine.
  Changing pixel aspect ratio of video clip?By Real Ramona in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jan 2012, 11:20
  Can an S-VIDEO lead send a 16:9 pixel aspect ratioBy kevthedrummer in forum Newbie / General discussionsReplies: 4Last Post: 21st Jun 2009, 11:02
  FLV to mpeg - what pixel aspect ratio?By gsh in forum Video ConversionReplies: 9Last Post: 8th Apr 2009, 09:19
  pixel aspect ratio in stills for dvdBy SexMoron in forum Authoring (DVD)Replies: 7Last Post: 4th Jan 2008, 09:11
  what pixel aspect ratio to use when making mpeg titile for DVD projectBy perfection in forum Newbie / General discussionsReplies: 3Last Post: 26th Oct 2007, 05:49
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
