    Dec 2007
    Hong Kong
    There exists mojibake when I try to add the subtle
    (orginally traditional Chinese subtle), Is there any
    solution to solve the problem?
    again,thx for your help ~
  2. Member dadrab's Avatar
    Mar 2006
    State of Denial, U.S.
    You haven't given us much to work with here. It's obvious you're trying to put in Chinese subs. It's also obvious your system doesn't support Chinese characters. But, what program are you trying to do it with? What are you authoring with?
    A little more info. will help your cause.
    Fact is, I had to google "mojibake." What I found might help you.
    See this: http://en.wikipedia.org/wiki/Mojibake
  3. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Read the thread title again
  4. Member dadrab's Avatar
    Mar 2006
    Sorry 'bout that.
    Dec 2007
    Hong Kong
    additional info to add: some of the subtle goes mojibake but some do not, is it the problem of the subtle?
    PS: thx for all your reply
