Guys I take avi vids and convert them to vcd, but than I burn them on to a dvd as data. That way I can put 2-3 movies on one disc. My old no name xwave dvd plays them, but its tearing up so I need to find a new one. What type do I need. I tried a dvd player that plays divx files, but it will not play any of the dvds that I have burnt as data. Any ideas?
My Philips DVP-642 can play such data discs. Other Philips models should do this, but you should confirm that by testing. I don't recommend the DVP-642 and I think it is no longer being made, but other recent Philips models should be able to do what you want.
Look for a Divx certified player. You can find a list at divx.com or you can search in the DVD players section here. You should then be able to burn the files straight to CD/DVD without any need to convert them. There will be some exceptions, but most files should work fine.
Google is your Friend
can anyone help me figure out why certain files wont play on media player
By DaLoKi in forum Newbie / General discussionsReplies: 1Last Post: 13th Dec 2010, 15:44 -
Please help! New DVD player doesn't work :(
By confuzedinTN in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Sep 2010, 14:44 -
Subs work on PC/VLC Player...but don't show up on dvd player
By bgart13 in forum SubtitleReplies: 9Last Post: 22nd Aug 2009, 19:06 -
how can i make sure my dvd will work in any player?
By el_nex in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2009, 18:22 -
how to figure out what decoder will work with Mpeg2schnitt
By spiritgumm in forum Software PlayingReplies: 1Last Post: 28th Sep 2007, 10:09
