I have just about got to grips with this VCD business thanks to some great help from everyone on VCD Help but I am desperate to do one thing.
I just want to record my VCD's/SVCD's onto video tape through my standalone player.
My player is a Cyber Home AD-M512 and it plays everything but I can't seem to be able to record. Somehow a friend of mine got it to work with the same player but with real difficulty. I would be more than grateful for any suggestions.
Thanks! :wink:
Sounds like you would need to hack you DVD players firmware to remove MACROVISION.
But why would you wanna put DIGITAL viedo on a ANALOG tape?
Try DVD HACKS to the left, then search YAHOO groups as well. -
Thanks alot BerrantRyke, I will try that :D
Just wanted to lend the tape to my friends who aint got DVD players! -
not knowing much about your problem, here is a solution that worked for a friend. if he pluged the dvd plyer to the tv it worked, if he went to the vcr it works he could plug the video and audio into his reciever and it worked. so wat we did was plug it into his reciever and then rca to his vcr. then it would work. for some reason it knew when it was connected to a vcr. but now it works. if your home audio reciever has video in plug it in there and try that. if it plays to the tv from your reciever than it should play to your vcr from your reciever to.
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 09:21 -
Standalone recorder that doesn't stop recording in response to VHS snow?
By thx1138d2002 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 2nd Dec 2011, 22:55 -
Ripping DVDS made in standalone player from VHS ..please help!!
By joelasso in forum DVD RippingReplies: 13Last Post: 25th Mar 2010, 03:25 -
Playback standalone VHS videotape player through PC
By kasfig in forum Newbie / General discussionsReplies: 6Last Post: 21st May 2007, 15:12
