hello to all
adding svcd2dvd to a new laptop with vista
all starts to load ok then it ask to add name ( at least 8 digits )
no matter what i put in screen flashes but wont take/work
when i restart proggy it will grab a new reg key but wont take any name i put in
any ideas how to fix this
thks much !
regards
Are you running the program as administrator? Did you install it somewhere other than 'program files'?
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
As you have vista - can you take a look at this thread about installation and Vista issues?
https://forum.videohelp.com/topic324278.html#1776530
(In particular: installation in a folder other than "Program Files" and running "As Administrator")SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
got it going ! i think the trick was to make a sep file folder and dont let it default to - program file folder
THKS all again !!!!!!!!!
registration problem SVCD2DVD
By stgreene in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 8th Nov 2009, 00:32 -
activating a Comcast DVR
By yknot2 in forum Newbie / General discussionsReplies: 8Last Post: 22nd Apr 2009, 19:34 -
re-activating my account
By loopylee1965 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Apr 2008, 18:11 -
svcd2dvd problem
By dvds2u in forum Newbie / General discussionsReplies: 1Last Post: 27th Mar 2008, 11:05 -
Activating PC- DV outputs
By 1234567 in forum DVB / IPTVReplies: 13Last Post: 19th Feb 2008, 17:43
