When I checked on my computer today, after a couple of days of putting it in Sleep Mode, I checked it and found that the light wasn;t on, even though the computer itslef was on.
I then held onto the "On" button until it shut off, and managed to get a blut light, but when I checked the monitor, it just said "No Signal."
It's an HP Media Center PC, with AMD 64 Live, NV Media, and Windows Vista, with an ACER monitor.
if you power off and then back on does the computer make the normal boot up sounds. fans go on, a beep, hard drives spin up?
There could be a number of reasons for this. The monitor cable might be loose. It might have a short. The resolution might be too high, and the monitor.
Believing yourself to be secure only takes one cracker to dispel your belief. -
Try booting into safe mode, usually the F8 key, or refer to your manual. If you get a screen, go to your graphics card settings and reset them if available. Then reboot.
I've had that happen a few times when the computer puts itself into sleep mode. Usually just booting again fixes it. I'm not sure if it's a prower settings error or the video card settings or the OS. Mine would fix itself when rebooted a couple of times, worst case. I quit using sleep mode on that computer.
Yes, pretty much everything else is in order.if you power off and then back on does the computer make the normal boot up sounds. fans go on, a beep, hard drives spin up?
if you're pretty sure the monitor and cable are ok and you don't even get the bios screens during bootup, then it sounds like it is probably the video card that died.
try removing it and using a different one if you have an old spare one or can borrow one.--
MPC won't display video on second monitor.
By zeek543 in forum Software PlayingReplies: 4Last Post: 19th Sep 2013, 22:21 -
MPC won't display on secondary monitor
By Monarch1st in forum Software PlayingReplies: 2Last Post: 17th Feb 2012, 13:11 -
Camera through computer so I can view on my monitor when in video mode
By Orion1122 in forum Newbie / General discussionsReplies: 0Last Post: 21st Oct 2010, 22:32 -
Win 7 - Computer goes into sleep mode after MS updates.....
By kenmo in forum ComputerReplies: 21Last Post: 23rd Jun 2010, 00:59 -
Computer Monitor Won't Power Up
By StrengthFTW in forum Newbie / General discussionsReplies: 4Last Post: 24th Nov 2007, 12:08
