Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. Tech_Girl DuBsTaR's Avatar
    May 2007
    Hi all,
    I'm trying to convert some Ts. files into DVD MPG2, but am getting errors.
    Version: HDTV2DVD 0.4
    Build: 0.4.2132.24074
    Type: System.NullReferenceException
    Source: HDTV2DVD
    Message: Object reference not set to an instance of an object.
    InnerException:
    StackTrace: at x14ee85f5d732c07f.xd3764d4f1e921081.AuthorDVD(xc76 139390a97debb xd2637df501625a82, x81974c36d7fdf1e1 xb4ee5c1758e9e983, Int32 xdc4f66b5011a3c9d, String[] x738d70b20493db82, Boolean x6b20cb17e8070d92, Boolean x3c21da9f928aac10)
    at x14ee85f5d732c07f.xd3764d4f1e921081.x2e6504f39decc 498()
    at x14ee85f5d732c07f.xd3764d4f1e921081.xf81783e1b359f fc3()
    Does anyone know what it means ?
    Thanks in advance.
    Oct 2005
    666th portal
    try another tool -
    HDTVtoMPEG usually works for me
    Jun 2008
    i get the same error and then i click on the "x" and then nothing happens. it sits at 0% and literally doesn't do anything. it also says in the right side column that there is ac3 audio sample rate 0 at 0Kbps. does this make any sense? when i add the video it plays in the window with sound, but it tells me there is no audio??? anyone have a clue?
