i am told my ati radeon will not run both at the same time. can someone recommend a card that will.
Who told you that?
Ever card I have ever had with S-Video out, and we are talking several dozen, is able to display both at the same time.
Now, setting up the software to do this, and getting it to do it by default on reboot every time, is another story. But I have never seen a card that couldn't do it, most especially an ATI Radeon card. -
Get the latest Vista drivers from ATI. Windows Vista probably only supplies basic drivers without s-video output.
http://game.amd.com/us-en/drivers_catalyst.aspx?p=vista32/common-vista32 -
Nelson37 is right.
You just have to make your S-video your secondary monitor.
Works more than fine in XP, doesn´t lose configuration after reboot.
Just open up your Display properties and there you go. -
Did you not ask the same question before?
https://forum.videohelp.com/topic348105.html
Video Run Time Gets Cut in half - and other conversion problems...
By scotsgael in forum ffmpegX general discussionReplies: 0Last Post: 3rd May 2010, 01:41 -
Hardware advice, video card & monitor, DVI or VGA ??
By Noahtuck in forum ComputerReplies: 7Last Post: 12th Jul 2009, 00:58 -
Need a video card that will run s-video and vga at the same time
By fordguy in forum ComputerReplies: 1Last Post: 20th Mar 2008, 13:57 -
Time for a Video Card Upgrade?
By dj4monie in forum Media Center PC / MediaCentersReplies: 21Last Post: 19th Dec 2007, 03:35 -
Need Help: Need a Video Capture card with FM (Time Shifing).
By monkyman in forum Capturing and VCRReplies: 1Last Post: 18th Sep 2007, 10:12
