after the hp support assistant i spoke with determined that it is faulty discs and not the burner.i come to you guys again.the problem can be explained by this example.sometimes it will load a disc sometimes it will not load a disc.my comp is hp compaq sr2180nx the burner is samsung TS-H652M.when i put a disc in and use windows explorer to open the drive,explorer continues to "load" while it cannot see or read the disc.it is as if the computer goes on halt or freezes as long as the disc is in the drive.programs freeze mid way through loading,if i eject the disc the program finishes loading.the disc cannot be loaded or read or whatever you'ld call it not even isobuster can read it.again this happens with random discs dvd-r or dvd+r one time it will load the next it wont,plagued by these symptoms.thank you
It could be several things.
The Samsung burner could be going bad. Burners do eventually wear out. If this one is a few years old, it may be time for a new burner.
The original burns might be bad and the discs can't be read because of that. You can verify whether the disc is readable at all by trying to play it on another PC or a DVD player.
The disc quality might be crap, which led to bad burns. I have a friend who uses cheap, crappy DVDs for stuff he sends to me. It's some old TV stuff not on DVD or VHS anywhere and he asks me to make a copy for my brother. It's a nightmare to copy his discs because they have so many bad sectors on them because the media he uses is crap. -
the discs are sony-r and memorex+r the burner is not more than a year old and the discs play in my standalone dvd player
Rent a movie and try to play it in your burner. Try load it few times, if it reads without problem, your trouble is mostly from cheep media. If it loads sometime, same as you are experiencing now, than your burner is ready for replacement.
another example is dvd decrypter hangs on "device not ready"logical unit is .....
i hate to do it to you guys and girls,but.i just used a dvd lens cleaner.so far all the discs that wouldnt load are loading and will play in wmp if i dbl click the drive,which it never did before.so it looks like the prob might be solved.for now im going to bed so ill have to give it the real test tomorrow.gotta love it.thanks for the responses. 8)
rip dvd using ripbot264 does not load complete movie
By magmo in forum DVD RippingReplies: 7Last Post: 11th Jun 2012, 20:51 -
1090T Computer Won't Load DVD Players
By wulf109 in forum Software PlayingReplies: 7Last Post: 23rd Apr 2012, 14:25 -
New pressed DVD's won't load on DVD-Rom but will on standalone
By chemchem in forum Software PlayingReplies: 1Last Post: 9th Feb 2009, 00:32 -
DVD does not load
By joelson in forum Newbie / General discussionsReplies: 4Last Post: 26th Dec 2008, 10:23 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 21:15
