Hello, new to the forum. Thanks ahead of time. Can I output to a big screen via s-video with my tv tuner w/out any input to the tuner (no signal coming in). My other question, if this does not work, is what video card can i get that will simultaneously output vga and s-video. The card I have (ATI Radeon 2400) will not do both.
What card do you have? Does it have s-video output? Tuner/capture cards typically don't have s-video outputs, just inputs.Originally Posted by fordguy
A Radeon 2400 should be able to output to both simultaneously. You probably just have a setup problem. Exactly what card do you have? Radeon 2400 is just a chipset.Originally Posted by fordguy -
i think the it is a Radeon 2400 XD. Gateway told me it would not do both and we could not find a way to change the outputs in the software. I will have to get the tuner card info. thx
If your card only supports one monitor, it probably won't support a monitor (vga out) and s-video out at the same time. Windows treats the s-video out as if it were a monitor, so without support for two monitors it's one or the others. It really sucks that some cards will have a dsub, a dvi and a svideo socket but only one can be driven at a time. If you get a new card, make sure it can drive two monitors if you want to use s-video (or HDCP) and a monitor at the same time.
Usually long gone and forgotten -
Every card I've had with an s-video port would could at least mirror the desktop on the s-video port while using the VGA or DVI port. The desktop resolution might be limited to 1024x768 or 800x600 while doing this though.
Probably even better would be to use ATI's Theater Mode where whatever is playing in a media player on the desktop will appear full screen on the s-video port.
If you really want recommendations for a new video card you should supply some more information:
PCIe or AGP (probably the former)
Is this computer used for gaming? That is, do you need a powerful gaming card? Vista? XP? Something else?
Is your big screen TV an HDTV? Does it have VGA, DVI, HDMI inputs?
How much do you want to spend? US$50? US$500? -
s-video on a big screen is not going to look very good...
As jagabo said, what TV do you have? What type of input connections does it have and what output connectors does your video card have. You may already have the right gear for a high-quality solution. Gateway will probably not help you with this because you are trying to do something they do not want to support for the masses.
I have a question how to get hd quality on a tuner
By sdavis in forum Capturing and VCRReplies: 5Last Post: 16th Dec 2008, 16:52 -
Dual Monitor and TV Tuner question
By alanngray in forum Newbie / General discussionsReplies: 5Last Post: 8th Jun 2008, 15:22 -
direct Tv question and tv tuner
By mohz in forum DVB / IPTVReplies: 3Last Post: 6th Jan 2008, 21:35 -
question about tuner card to record TV
By jimdagys in forum Capturing and VCRReplies: 11Last Post: 22nd Nov 2007, 07:17
