Hi,
I have been using Nero 7 to burn DVD's. I tend to burn music videos on to DVD for promotion for parties.
I use Nero to have a video play in the background of the main menu and during videos put scrolling text.
Is there any other software which can do this which is as good as nero or even better that i can purchase or download?
It normally takes around 3 and a half hours to burn the disc from start to finish and occassionally i find that the videos tend to jump or skip (I think this does not happen when i burn at the slowest speed). I have just bought Nero 8, hopefully that will be an improvement.
Kind Regards
Jump or skip problems could be bad/crappy media, frame rate conversion between PAL/NTSC or other conversion problems.
What is your source video details? Like what video and audio codec and video framerate?
Are you making PAL or NTSC?
Have you tried different dvd media? -
Not sure about the sourse video details off the top of my head. But i find that when i burn at a slow speed i don't have any problems. I always make PAL dvds.
I have tried different dvd media. The one i am using at the moment is very good. -
To put video behind your menus you need an authoring tool that supports Motion Menu. Personally I consider Nero an authoring toy, but some like it. You will have to consult your manual/help files to find out if it supports motion menus. I use DVD Lab Pro for authoring, which can easily do motion menus itself, however I prepare them in Vegas and import them as it gives me better control.
Scrolling text will have to be animated by hand in an editor, not done at the authoring stage.Read my blog here.
Help with iDVD menu options
By HowardNeedsHelp in forum MacReplies: 0Last Post: 27th Aug 2009, 20:50 -
Vista compatible disc authoring/burning software with sub menu options?
By wetcamelfood in forum Authoring (DVD)Replies: 7Last Post: 7th Jan 2009, 21:08 -
Authoring Multiple Language DVD with multiple language menu options
By kemimich in forum Authoring (DVD)Replies: 7Last Post: 8th Sep 2008, 16:29 -
how to? minidv tape to dvd best options
By pantsdavies in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 9th Nov 2007, 20:35 -
tape to dvd am I using the better options
By pantsdavies in forum Authoring (DVD)Replies: 1Last Post: 6th Nov 2007, 11:32
