For example, I can watch an .avi file while it is downloading because of the header information being at the start of the file. I can also watch an .mpg file while it is being encoded by SUPER...
However, when it comes to .mp4, .mov and .3gp I cannot watch the video while it is being encoded from *usually* an .avi format, which does not play on the iPod.
Is there any way I can watch a video while it is being encoded by SUPER using any sort of container/encoding combination? If there was and I could stream the video file as it was being encoded to my iPod wirelessly, that would be amazing!
you are confusing me with your question
it sounds to me like you are opening your mpg, with (2) different programs at the same time, one is streaming to your ipod, the other is encoding
AFAIK super does not offer any preview mode while encoding, for any file type
although it does offer a capture mode, for web streams
capture and encode/conversion are (2) different processes
you might be watching the capture stream as it comes in,
but encoding is either faster than real time or slower than real time,
usually with NO sound available , and NOT suitable for actual viewing, although preview mode of some encoders, gives you a visual check on quality
Ripbot264 iPod format will play on iTunes but won't sync to iPod/iTouch?
By Riley007 in forum Blu-ray RippingReplies: 2Last Post: 31st Dec 2010, 01:04 -
Rip DVD to one file which can be played on an iPod
By marcelg in forum MacReplies: 20Last Post: 9th Sep 2009, 20:12 -
iPod last.fm-type statistics program (total songs played in last week, etc)
By Salva Veritate in forum Portable VideoReplies: 0Last Post: 22nd Jan 2009, 16:54 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 10:15 -
Ipod 5G Cant play one certain videoclip wich has been encoded as others
By Igniss in forum Portable VideoReplies: 4Last Post: 25th Jun 2007, 13:47
