My Panasonic S-27 moans and groans for 30-60 seconds when reading a disk. It started doing it a couple of months ago. Once it reads the disk, it works fine. This happens on about half the disks I put in and sometimes on disks it had no trouble with before. Is there a simple repair?
I suspect the bearings on the player could be wearing out and unless the discs are perfectly balanced, you may be getting more noise. Some DVD players/burners rev up to do the initial read of the disc, but most ones like that do that from day one. I had one that sounded like a airplane taking off.
But if you are getting no read errors, it may not be a problem, at least yet.
And welcome to our forums.
My Panasonsic DVD recorder used to moan like that too, and over time, it became worse. It turned out I just needed to clean the spindle on the DVD drive. If you can open up your player, the following thread has instructions for cleaning the spindle:
https://forum.videohelp.com/topic346729.html -
Thanks very much, redwundz and usually-quiet. I'll try cleaning it as that thread suggests.
I think the S-27 still used a DC brush spindle motor. If so, it's about to go and you'll get the dreaded H07 error soon.
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 07:28 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 12:55 -
Player nightmare! (BS Player and Media PLayer Classic)
By 2710 in forum Software PlayingReplies: 1Last Post: 9th Jul 2010, 06:28 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 09:15 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 06:05
