I am using Any DVD Converter to convert DVD files. I have successfully converted 3 movies. One other movie I cannot convert. When the application reads the DVD in preparation to encode, the message "seek failed on an unnamed file" is presented. Can you help?
I've never used the tool. You don't have any specs in your post, but if you are converting from DVD to avi, try using AutoGK. It has the best quality of the tools that I've tested.
Otherwise, I suspect the disc isn't ripping properly (assuming you have to RIP the DVDs before conversion). If not, you likely have a dirty/scratched dvd or your burner is having read issues.Google is your Friend
Cannot seek DVD on some computer players
By bhilgenkamp in forum Authoring (DVD)Replies: 1Last Post: 26th Apr 2012, 23:44 -
Full Time Seek Bar
By Bruno AUgusto in forum Software PlayingReplies: 2Last Post: 17th Nov 2011, 06:52 -
CUDA seek time
By coolxal in forum Software PlayingReplies: 2Last Post: 9th Sep 2011, 22:03 -
FLV1 seek problem
By jenova in forum Newbie / General discussionsReplies: 8Last Post: 13th Jul 2010, 21:00 -
cannot seek in big (>2 GB) XVID files
By adwiel in forum Video ConversionReplies: 1Last Post: 25th Jan 2008, 00:41
