I have "Hellsing; Ultimate Volume 2". I just got it and my PC doesn't care for it to much haha.
Well it has this protection on it so it was really hard to RIP it to my pc but here what I managed to do.
I used "RipIt4Me" and ripped only the "Movie" which came out to be 3 .vob's. 1 GIG, 1 GIG, 500 MB. I encoded them all using AutoGK. I set the resolutions all the same and frame rates of course at at 23.??? and Audio to VBR MP3 128.. It encoded them great. Took that 2.5 gigs down to 500 mb and is in good quality still. So I then tried using VirtualDubMod to combine "Append" all 3 clips together and I get this error message:
http://img411.imageshack.us/img411/1428/errorsag3.jpg
and here si the Properties of the clips:
http://img379.imageshack.us/img379/2497/propertieskh2.jpg
I did just notice that he last one is 29fps.. but its not the problem, because I'm only clickign the first 2.. and they are the same except the bitrate..
Basically, Is it possible to combine these 3 clips with all different bitrate, or even better what program will allow me to specify the exact bitrate I want them to be?
Thanks In Advance
Ahh. man. Thanks. I'm Gonna go try that. Sounds perfect. I'll post results.
Thanks! -
VOB's Merged very fast. and was very easy to use. Encoding now. Gonna be several hours. So I'll tell you how great it worked. Thanks Again.
Just make sure when you merged them that they were in the correct order in the preview window....
I've had them go,
2VOB
3VOB
4VOB
5VOB
1VOB
after adding them all & have to move the 1st VOB back to the top before merging. -
You could also append the VOB's in virtualdubmod or avidemux and encode with the same application.
Converting dvd with multi sections
By Peter1954 in forum Video ConversionReplies: 1Last Post: 14th Dec 2011, 04:42 -
What program to cut out unwanted sections of DV-AVI for archive
By piperpilot12w in forum EditingReplies: 6Last Post: 30th Aug 2010, 00:52 -
Joining two VOB sections from a DVD.
By jnetty99 in forum EditingReplies: 10Last Post: 14th Jul 2010, 18:36 -
DVD to Mpg - Missing Sections
By Tyler2000 in forum DVD RippingReplies: 1Last Post: 11th Dec 2008, 12:29 -
Editing Sections of DVD's to a new DVD without losing quality & keeping
By notpinky in forum DVD RippingReplies: 3Last Post: 18th Jul 2007, 14:51
