Hey guys, since I have to use a stand-alone VCR most of the time to copy my home-recorded movies from VHS to DVD(I have a DVDr/VCR combo), on certain movies of mine that were copied from either a store-bought tape or rental tape, I experience some staticy or distorted audio. Whats causing this? Some of my older videos that were recorded from PPV or HBO and Cinemax and even from older rental and store-bought tapes dosent cause this, but on some of the newer movies like Bad Boys II and 2 Fast, 2 Furious that were copied along time ago from rental tapes, I cant record them to DVD because I get this staticy or distored audio playback. To my knowledge, Im only having this issue when recording from a tape of mine that was recorded from a newer movie tape that was copied from either a store-bought or rental tape. If I were to copy the same movie from a tape that I got from PPV for example, I dont have a problem.
Oh, since most of my movies have started off with some sort of a copyguard, I cant use the VCR portion of the unit to play the tapes because the DVDr portion still picks up a trace of the copyguard so thats why I have to use a seperate VCR and an in-line video clarifier to filter out the rest of the copyguard.
I have experienced this on home recorded vhs tapes that are over 15 years old, switching the audio out via the menu to mon usually removes the noise.
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
Hmmm, my problem is exactly the opposite. My older ones are fine.
Help with capturing VHS to make DVDs of home movies
By jrodefeld in forum Capturing and VCRReplies: 7Last Post: 1st Apr 2011, 01:09 -
Newb needs help with VHS home movies
By Subsoniq in forum Newbie / General discussionsReplies: 11Last Post: 4th Jun 2010, 18:06 -
VHS home movies to DVD and....?
By sdineen in forum Newbie / General discussionsReplies: 3Last Post: 16th Jul 2009, 08:35 -
Simplest way to convert home VHS movies to DVD using VirtualDub?
By Pickngrin in forum Capturing and VCRReplies: 11Last Post: 21st Aug 2008, 09:32 -
What bitrate to rec standard VHS?
By jsmithepa in forum RestorationReplies: 31Last Post: 20th Jan 2008, 13:52
