Ive noticed that rarely a d/l that usually might have a rar. file has a (null).xx
it not a dot but a larger dot 1/2 way up the space
usually macpar renames these to the correct name and extracts
what created the (null) and why?
cheers and thanks
				Results 1 to 9 of 9
	MPro 2.66 3GB RAM 1.5TB HD's
 MigliaMiniHD
 QTPro, MPEG2 add on MPlayerX2
 MPEG Streamclip
 24 + 21" samsung flat panels
 G4dual 2GB
 AlchemyDVR card
	null's are usually created by improperly downloaded files.
 A stall in the network, a crashed computer, a power blip
 that affected the cable modem. That's why Pars are great;
 they rebuild anything that didn't completely download due to
 these sort of things...."Everyone has to learn, so that they can one day teach."
 When I'm not here, Where can I be found?
 Urban Mac User
	how odd. from this one particular source all the material comes d/l w 'null' at the same time others are fine. minimal PARs rebuild it though.
 cheers and thanksMPro 2.66 3GB RAM 1.5TB HD's
 MigliaMiniHD
 MPEG Streamclip
 G4dual 2GB
 AlchemyDVR card
	the nulls also could have been created on the poster's end,
 he/she could have had a "blip" during the .rar creation
 on their end."Everyone has to learn, so that they can one day teach."
 Urban Mac User
	as I thought. Im hope full that the creator will add larger % par2s as these are ****critical*****
 ****c00king*****
 cheers and thanks againMPro 2.66 3GB RAM 1.5TB HD's
 MigliaMiniHD
 MPEG Streamclip
 G4dual 2GB
 AlchemyDVR card
	one of the DL ers at c00king added this to the null issues:
 'When I download with GrabIt it does the NULL thing for me but I installed NewsLeecher and it downloads OK.
 UnkleZed'
 very curious about this.
 cheers and thanks for your (continuted) inputMPro 2.66 3GB RAM 1.5TB HD's
 MigliaMiniHD
 MPEG Streamclip
 G4dual 2GB
 AlchemyDVR card
	my c00king pal w the null issues found this:
 I decided to do my own research and came across this on a forum:
 "I noticed that files posted using Newsbin 5.0 create this problem with multipart files. If you use Newsbin 5.0 to download them, they are downloaded properly. But with Agent or Grabit, they are named null. Agent will not overwrite the files though so you can rename them using the par file. Grabit simply overwrites the file so at the end of the download you are left with one file called null and the directory is empty."
 So there you have it. I'm posting with Newsbin 5.35. If anyone wants to recommend a good posting program, I'll give it a try.
 any idea on what to tell a PC c00ker to do?
 advice ****urgent**** as much c00king to do this week that end!
 MigliaMiniHD
 MPEG Streamclip
 G4dual 2GB
 AlchemyDVR card
	None that would be compatible or that he (the PC user) might want to hear,
 rotus.
 as long as you have Pars, you'll be ok on your end.
 Just tell your PC friend to make Pars so that everyone can fix
 the issue once they downloaded the files."Everyone has to learn, so that they can one day teach."
 Urban Mac User
	Thanks So Much
 the PC changed the newsreader or poster and
 all is fine!
 we are all now "c00king" gas!
 many thanks!MPro 2.66 3GB RAM 1.5TB HD's
 MigliaMiniHD
 MPEG Streamclip
 G4dual 2GB
 AlchemyDVR card
  failed pBuilder -> RenderStream ( NULL, NULL, pPin, NULL, pMux)By newbie_noob in forum Newbie / General discussionsReplies: 0Last Post: 19th Feb 2010, 09:10
  weird null pointer exception when intialization Windows Media EncoderBy George2 in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2009, 00:25
  Also recently DL'd: (Null) etcBy rotuts in forum MacReplies: 3Last Post: 8th Nov 2008, 01:14
  can we add null packet to make a CBR h.264 contentBy jacopski in forum Video ConversionReplies: 0Last Post: 28th May 2008, 00:55
  DCMA's No Backup Provisions Now Null and Void in USA!!!!!By videobread in forum Newbie / General discussionsReplies: 25Last Post: 9th Jan 2008, 13:26
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
