I used DVD Fab Platinum to burn a DVD. I think DVD Fab Platinum uses ImgBurn (I'm not sure about this) but during the burn process, there was rapid changes in the disk speed during the burning. After the disk was burned, when I look at the physical disk and can see a wide concentric band (in the burned area) where ( I think) the laser was getting more and less power during the burn. In the past, anytime I see a concentric band in the burned portion of the DVD, that was a bad burn, but this DVD plays fine. My question is, why is there a concentric band on the DVD when using this burning program. I normally use Nero and never see this kind of pattern on the disk. (I filled this disk to near capacity and the concentric band is in the burned portion.)
Zonal burning rings.
If you burn at 16x, for example, the disc starts a burn at 4x, then 6x, then 8x, etc. The 16x is only that last few hundred MB near the end. The change in laser causes the dye colors to alter.Want my help? Ask here! (not via PM!)
brighten only a portion of a video?
By magnumpy in forum EditingReplies: 1Last Post: 23rd Dec 2011, 01:00 -
Removing more than one portion of a video at once.
By M Bruner in forum EditingReplies: 2Last Post: 21st Nov 2008, 05:17 -
Portion of video (left and right) being cut-off when burned to DVD
By doggieusa in forum Authoring (DVD)Replies: 3Last Post: 2nd Mar 2008, 20:54 -
Laptop DVD Burner suddenly only burns small portion of DVD
By hydrurga in forum DVD & Blu-ray WritersReplies: 9Last Post: 13th Feb 2008, 04:39 -
Vertical band moving across screen - DVD/HDD recorder
By wizbru in forum Newbie / General discussionsReplies: 3Last Post: 16th May 2007, 03:20
