    Jan 2003
    Nassau, Bahamas
    I just recently reinstalled xp, and before i installed my codecs and stuff, i nstalled sp2. Now all of my divx, xvids and eall those other file formats all come out dark, green and other colours. What can i do to fix it, is there a codec pack i can get that is compatible with sp2!!!!!!!!!!!!!!
    "If u cant eat it - u dont need it"
    "Baby - If i dont hit it, Who will?"
    "Why is Abbreviation such a long word"?
    USA
    Usually installing a codec pack is what can cause that problem, so I wouldn't try one to cure it. Try installing ffdshow. It's not a codec pack, but can handle most formats. In the case of Xvid, a corrupted codec can cause pink and green blotches. Try uninstalling and reinstalling it.
    I don't know what SP2 would have to do with the problem. But you might try VLC and if it works, then you likely have a codec problem.
  3. If it's not a codec problem, another possibility when you do a re-install is your graphics card settings and video player settings get reset. This happened to another poster very recently if you do a search.
    Check your video overlay settings.
