I'm wanting to play a DVD I purchased in Germany on my TV's DVD player but it doesn't "see" it as a recognized format. It plays fine on my computer's player. Is there any way to copy it so it's encoded with a recognizable format for my Tv's built in DVD player. It's a Magnavox brand and otherwise plays other stuff fine.
Help is greatly appreciated. I'm a novice but mentor other lessor novices
thanks
	Maybe because of region coding. Have you tried made the dvd player region free? Check for region code hacks under Hacks here to the left or google it.
 Your dvd player might not support PAL DVDs also, then you could convert it to NTSC using ConvertXtoDVD.
	Thanks for your reply.
 I'd heard of regional coding but thought at time it'd be a download of a codec or something. Since then I've read that one can make computer dvd players region free, but wasn't sure how that would apply to my TVs built-in player.
 I'll look under hacks and try the convertxtodvd right away. +++
	Thanks for your help. Still having difficulties so here's my test using a dvd sent to my mom to watch from Germany (German Version of Out of Africa.
 I place the DVD in the computer's player. I open ConvertXtoDVD3, select "file", then select "add video file".
 I then point program to the DVD player. Two files are shown. Audio Ts and Video TS. I open VideoTs and select the whole list.
 When I select "convert" I get a message stating one or more files can't be converted: e:\video_ts\vts_03_0.ifo"ignored.unknown file format.
 Please help my mom's 80 and it'd be nice to let her see some of these movies in German.[/img]
	You are likely having two issues with your disc. First, as you already know, it is the wrong region. Second, Germany uses the PAL video format.
 As to your ConvertXtoDVD issue, you can't point it directly to the DVD. Most DVD's have copy protection which conversion software can't handle. Try an app such as DVDFabDecrypter, RIP the original DVD to your HDD, then point ConvertXtoDVD to the files on your HDD.
 On a side note, according to the specs, the only release with German audio/subtitles is the Australian R4 release. Which is also PAL, just curious which version you actually have?Google is your Friend
	And my education begins ... two parts to this problem:
 1) first rip to hardrive using DVDFabDecrypter
 2)convert it to a format compatible for my TV's player using ConvertXtoDVD
 The movie is now 30 miles away so at moment can't tell if it is the Aussie version or not... will let you know ...
 Great site!
  Computer Guys Braggin' Time: What have you built that AIN'T a computer?By ahhaa in forum Off topicReplies: 22Last Post: 8th Feb 2010, 16:19
  Not sure if I need a dvd + vcr recorder player with built in tuner or notBy zalman001 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 1st Oct 2008, 11:33
  dvd plays on stand-aone player & TV, but not on computerBy ibzomie in forum Newbie / General discussionsReplies: 1Last Post: 19th Jan 2008, 16:18
  Foreign DVD plays on computer but not on DVD playerBy johnharlin in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2007, 23:28
  DVD plays on Sony DVD Player but cannot be read by ComputerBy jeneralzod in forum DVD & Blu-ray WritersReplies: 3Last Post: 28th Jun 2007, 22:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
