I have a couple of .isx .sub subtitles which i want to edit.It is of my knowledge that subtitle workshop doesnt jabdle them,so what can i do to add a delay of some seconds to them?
They'are of a movie that i've encoded in to two xvid files.The first file needs for a delay of 13 sec to be set and the 2nd file of 11.4 .I also need to cut a couple of sentences at the end of file 1 and paste them in the start of file 2.
How do i go about doing those things?
Thanx you.
That actually did it,you needed to add delay in the idx and save with subrsync.
Althoug getting the last setences and transfering them first in two the second file will be much of a hassle.I guess i would first have to join both files and then cut at the given point,and i just dont want to get into that,its just only a couple of sentences.
Thanx my friend.
Add permanent subtitles to S/VCD,DVD,AVI with ffdshow/vobsub
By Baldrick in forum User guidesReplies: 74Last Post: 4th Oct 2011, 05:11 -
m4v subtitles (vobsub)
By roughsporty in forum SubtitleReplies: 2Last Post: 18th Mar 2011, 09:04 -
VobSub subtitles to SRT,how?
By jepe in forum SubtitleReplies: 4Last Post: 14th Apr 2009, 14:49 -
Permanent Subtitles with VobSub
By daniscp in forum EditingReplies: 0Last Post: 18th Dec 2007, 09:42 -
Subtitles using VobSUB
By rafael_laffront in forum SubtitleReplies: 0Last Post: 8th May 2007, 16:39
