I Used TMPGEnc DVD author to cut out parts of a dvd but now the audio is well out of sync how can I fix this
thanks all![]()
Well Tried all of those but 1/2 way into video this is when audio is out of sync bad isnt there a program where as you can slow or speed up audio to match video
Audacity or Goldwave can do that, but you would probably need to extract out the audio as WAV file. https://forum.videohelp.com/topic348100.html
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
