I have been trying to use Slide Show Movie Maker to make mpg stills with audio for a VCD menu system. I used it only once then it stopped working completely. I'm fed up with the program. I was wondering then, if there was another program that could do it for me. I just need a MPG with a still and audio that comes in a couple seconds after the still loads that I can use in VCDEasy to use as a simple menu system. This is what SSMM was supposed to do for me and I got it to work once but I messed up the music intro offset and then I couldn't get the program to run properly again. So, I was wondering if there was another program to do this for me... perhaps one a bit faster and more reliable!?
Thanks in advance.
-=A-S=-
Thanks. I tried the program you suggested, however I can't seem to find a way to control the default effects the program places on music and slides it uses.
MAC DivX Author Equivalent?
By innovyse in forum Authoring (DVD)Replies: 4Last Post: 6th May 2011, 10:51 -
Mac equivalent of DGIndex?
By ecc in forum DVD RippingReplies: 0Last Post: 10th Dec 2010, 10:37 -
VOB2MPG Equivalent for BluRay
By user89273 in forum Blu-ray RippingReplies: 2Last Post: 1st Apr 2010, 09:32 -
equivalent filters from Vdub to Avisynth
By cd090580 in forum RestorationReplies: 3Last Post: 14th Aug 2008, 13:28 -
Quality-equivalent bitrates between codecs
By Overwind in forum Video ConversionReplies: 3Last Post: 16th Aug 2007, 13:51
