I'm trying to add a 5 second intro video to some avi movie files I downloaded. I tried those video joiner programs, but unless my 5 second intro video is encoded exactly the same way as the main movie it will not join the two files together.
Anyone have any ideas on how this can be done without having to re-encode the whole movie?
Results 1 to 12 of 12
What about re-encoding the 5 second intro video instead?
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. -
That's the way it works - You can't seamlessly join 2 things that have different properties.Originally Posted by solar2504
Just make sure your intro clip is encoded exactly like the main movie, and it shouldn't be too much work.
Have you tried AviDemux? It is said to be better for this kind of operations.
/Mats -
Well I tried re-encoding my intro, i matched the resolution exactly and they're both xvid files also but they still won't join. The audio is some weird bitrate that I can't seem to match.
I've all but given up on this endevor.
All I really wanted was a way to add my websites URL into the beginning of every movie without going through the rediculously long process of re-encoding a whole movie.
Is there some program out there that will let me maybe add an image file like a jpeg to the beginning of a movie perhaps? just something to get my website shown for a few seconds before the movie starts. -
Again - all clips you want to join must have exactly the same properties. Did you try AviDemux?
/Mats -
Most likely, your main movie has VBR mp3 audio. Impossible to match, and generally a PITA in every respect.
/Mats -
Use Virtualdub with either Donald Graft's Logo filter or the built in Logo filter and use Blend mode with the Curve editor and Smart Render to only encode the filtered part.All I really wanted was a way to add my websites URL into the beginning of every movie without going through the rediculously long process of re-encoding a whole movie.
You can use a blue background to make the movie show through and the text visable. With the curve editor, you can make the text fade in and fade out and control how long the text is visible. -
Add you intro video as a "first play" into TDA3. That way the intro will play when the DVD is inserted.
...If we were talking about Video DVD creation, yes, but that's not my impression.Originally Posted by marioval
/Mats -
generally, the problem is the audio part. a round about way which should work-convert both to video cd format (both to NTSC or both to PAL with TMPGEnc). Join them, with TMPGEnc. Demux the audio out of the joined files. Demux the video (direct stream copy in vdub) from both avi files. join them with vdub. use vdub mod to load joined video, audio from the joined vcd files. reencode only the video.
changing sampling rates of audio in avi files to match should work theoretically, but practiically it doesn't because vdub always finds a miniscule difference.
Small clip or video at the beggining of movie
By DeNeDe in forum Newbie / General discussionsReplies: 19Last Post: 3rd Jun 2011, 14:44 -
Add a intro clip onto a DVD to play before chapters apear NERO VISION
By cp_ozie in forum Authoring (DVD)Replies: 11Last Post: 25th Jan 2009, 19:04 -
Trying to add a small intro clip to a movie file without re-encoding
By solar2504 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 18th Mar 2008, 02:53 -
How to add an age clock to the movie clip
By iho in forum EditingReplies: 3Last Post: 2nd Nov 2007, 04:42 -
What is the easiest method to add intro clip on DIVX ?
By rob3rtz in forum Newbie / General discussionsReplies: 3Last Post: 7th Oct 2007, 05:35
