Falcon DVD R
HP DVD R
Maxell DVD R
Memorex DVD R
Optical Quantum DVDR
Philips DVD R
Taiyo Yuden DVDR
TDK DVD R
Verbatim DVD R
I used to buy Ridata Ritek, but after a while, some skipped and didnt burn. So I am looking for better brands. I heard Verbatim is good but not sure if there is a better one fro mthe list in your opinions.
http://meritline.com/dvd-r-blank-media-1.html
thanks!
Get either TAIYO YUDEN or VERBATIM. The rest of your list is considered crappy media.
out of those two, what is ur recommendation, i have only used verbatim before.
I use both TAIYO YUDEN and VERBATIM. Buy what you can afford. TY usually cost more.
Blank DVD Disc Brand?
By Nitro89 in forum DVD RippingReplies: 7Last Post: 20th Mar 2009, 10:05 -
Should I buy DVD-R with no brand name?
By greglee in forum MediaReplies: 6Last Post: 16th Aug 2008, 01:49 -
Best brand for lightscribe cd's & dvd's
By DonGallego28 in forum MediaReplies: 3Last Post: 7th Sep 2007, 16:41 -
DVD-R - Which Brand Produces the Best Result?
By markannab in forum Authoring (DVD)Replies: 1Last Post: 2nd Jun 2007, 04:37 -
What brand DVD-R is best for the G5?
By Rich W in forum MacReplies: 5Last Post: 23rd May 2007, 20:08
