I really don't know much about this sort of thing...and I tried about 4 different programs until I got simplemoviex which actually works...catch is that they plaster "TRIAL" over the damn video. I think the audio's 4.10 seconds ahead of the video, if that helps.
I know there's already a thread about .avi files...but I didn't see anything for a mac.
I really appreciate any and all help. Thanks!
p.s. - I downloaded these episodes in a torrent and a .sfv came with...should that be able to detect syncing issues? because it didn't... o_o
Oh, also...on one of the files...it started out out of sync...and then suddenly switched in sync. strange.
Your major issue will be finding another Mac user. Most of the users here are on Windows PC's.
Sync issues are typically a pain in the a##. If it is a consistent amount of time from start to finish, you can extract the audio (using an audio program, I don't know what to recommend for a Mac user) and remove audio from the beginning if the audio is delayed or add blank audio to the beginning if the audio is early. Then remux the audio back into the file. If the delay isn't consistent, you likely won't get very good results and your time is best spent finding a better copy/version of the file.
As for the .sfv file, that is used for error detection so that you know whether the file was corrupted or not (ie: missing/incorrect data). It doesn't have anything to do with the quality of the file.Google is your Friend -
QT Sync may work for you. Once you manage to get the sync correct (and you may preview, modify, preview, modify...until you are satisfied; then a "Save as..." will put the whole thing into a ".mov" container (without transcoding, hopefully). Process as you require afterwards (for iPod, DVD, etc.).
Audio/video fine on PC, out of sync on Mac
By scrolls in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2012, 22:48 -
audio video avi file out of sync when converting with nero
By paulthewall37 in forum AudioReplies: 2Last Post: 28th Feb 2010, 19:06 -
can i sync audio on an avi file on mac
By dudeboy in forum MacReplies: 4Last Post: 28th Aug 2009, 11:47 -
Audio Sync Problem, Repairing and AVI File?
By JerryRecords in forum AudioReplies: 1Last Post: 5th Dec 2008, 00:38 -
Audio out of sync in AVI file by varying amounts
By smc888 in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 12:23
