I have this iso file that is 7.95gb in size. It is, once converted disc 4 of 4 of season 5 of an old tv series. The problem is when I use dvdshrink to shrink it to put on a starndard dvd it says it "encountered a problem". I was able to shrink and burn disc 1-3 using dvdshrink. Any help would be great.
Thank you
Instead of trying to do it all at once, first see if the ISO is okay.
One good way is to use DaemonTools. This can make an ISO appear to be an actual disk, so you can play it, or extract the VOBs from the virtual disk
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 16:51 -
Dvd to iso
By skorpinok in forum Authoring (DVD)Replies: 5Last Post: 16th Dec 2010, 13:32 -
ISO to DVD
By Spack in forum MacReplies: 2Last Post: 19th Nov 2010, 12:16 -
7GB .iso to DVD
By aslan in forum Newbie / General discussionsReplies: 6Last Post: 24th Jul 2008, 09:26 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 19:01
