I just purchased a PC with Vista![]()
What is the most stable; user friendly version of Nero for Vista?
All the versions are listed here:
http://www.afterdawn.com/software/cdr_software/cdr_applications/nero.cfm
Results 1 to 16 of 16
Version 8 is fully compatible. There were some versions of 7 that you need to use XP compatibility mode.
Believing yourself to be secure only takes one cracker to dispel your belief. -
I use Nero to burn Video-dvd's all the time. I am a member of this site, but deflecting the question with something that was not asked for does not in any way shape or form help the OP.Originally Posted by bendixG15
Everyone is different, but see above response. I use Nero to make Video-dvd's all the time.Originally Posted by jman98Believing yourself to be secure only takes one cracker to dispel your belief. -
I am with Dv8ted2. I have used NERO since version 4 and now 8 and never have any issue.Originally Posted by Dv8ted2
To OP: you're running Vista, you should go with version 8. I have three XPs and one Vista at home and I never see any glitch about NERO. The most functions being used the most are DVD-ROM, CD-AUDIO, DVD-VIDEO and CD-ROM. I hardly use other functions and maybe these are the most stable functions of NERO. Don't quote me on that one. Don't feel horrified to use NERO 8 under Vista.
vcdlover -
Nero is a piece of shit. It doesn't burn DVD-Video correctly. It's fine for data, and for music, but other software STILL works better, and for free of all things.
ImgBurn for DVD-Video and data, on either SL or DL media. I forget the name of the free music tool. I still use Nero 6 for my music.
Answering somebody's question is sometimes best answered by the unnamed choice. If somebody had an STD and asked if he should chop off his penis with a scissors or a hatchet, wouldn't your answer be "go see a doctor and get a prescription"? Yeah, it's an off-the-wall scenario, but sometimes that's needed to illustrate a point!Want my help? Ask here! (not via PM!)
How do you figure?Originally Posted by lordsmurf
If I asked should I eat an orange or an apple, and you answer with a banana, how in the world do you think you have helped me? I did not ask if I should eat a banana. Your opinion is subjective. Not everyone thinks like you do. I happen to like Nero.
I mainly use Nero Express to burn everything, and I use the wave editor to edit music.
For the record, I also use imgburn, but please keep the subject on topic, and give the answer that they are looking for rather than something that was not asked for.
Apple? Orange? Banana? You didn't give a goal.
For example, if you wanted extra potassium, then neither the orange nor apple would be an appropriate fruit.
DVD-Video is the goal here, and Nero is a poor means to that end. It's not an opinion. It's a fact that Nero does not properly adhere to the DVD-Video specs.
This is not about simple choices, but rather how to meet a certain goal with successful results.Want my help? Ask here! (not via PM!)
Agreed w/ LS. Certain aspects of Nero still have merit (I guess - haven't touched since the botched v7 releases), but overall there's better stuff out..And FREE no less. I use imgBurn for all my video/data burning nowadays. No nonsense stuff, quality burns every time (although quality hardware/media do come into play here too). Nero has gone from a once (fairly lean) good program to a piece of bloat ware, whose components are often outclassed by other, more focused softwares.
You know the old saying jack of all trades, master of none. IMO it applies quite nicely here.
On topic though, when Vista compatibility is of chief concern, go w/ v8.whatever-it-is-now -
Before this veered off into a discussion about how to answer questions, I think that everyone who replied to this post was sincerely trying to be helpful to the OP. Hopefully the OP is not offended by the suggestion that a different program might be a better choice for one of the things that Nero does. In any case he/she has an answer to the question posed about which version of Nero would work better with Vista.
For what it's worth, I used Nero to burn DVD's for about two years. Although I have now switched to ImgBurn for that, it's mostly because I tend to err on the side of caution, and because I like the idea that the discs it burns are fully compliant with the standard. However, based on what I have been told about exactly what Nero does incorrectly, it is unlikely to ever cause a problem for me, or any one else who does not do professional video work.
However, there were a couple of other things that I noticed about ImgBurn that might make it a better choice for some. ImgBurn offered more options for burn speed and internal labeling for the disc than does the version of Nero Express that I have, but then again this may not be anything that interests the OP either.
[Edit] I read some posts this morning about problems people were having with Nero, and it reminded me of something that might be important. Nero does not handle the transition between layers very well when creating dual layer discs (I probably forgot that because I never use them), but this may not be anything that the OP cares about either.
Will the Nero LiquidTV Tivo remote bundle work on Vista MCE?
By yoda313 in forum Media Center PC / MediaCentersReplies: 0Last Post: 21st Nov 2008, 15:53 -
Cannot read Nero-burned CDR (Vista) on XP
By walter4h in forum ComputerReplies: 4Last Post: 27th Mar 2008, 02:20 -
Please recommend any good Nero alternatives for Vista
By driguy in forum ComputerReplies: 1Last Post: 17th Feb 2008, 15:51 -
What is the difference between Vista basic and Vista home premium?
By davidsama in forum ComputerReplies: 18Last Post: 27th Oct 2007, 13:01 -
Sharing TV - 1 Vista Media Center Server to Vista Media Center PC
By JBredensteiner in forum Media Center PC / MediaCentersReplies: 8Last Post: 14th Jul 2007, 02:33
