I have a couple of videographer friends who do event videography, primarily weddings. They generally use two or three cameras and then edit them together to generate a final video using multiple camera angles for a more professional final result.
However there are two types of editing. One is compositional editing where transitions, cutting, joining etc are done. The other is technical corrections and filtering where parameters such as white balance, brightness, contrast, gamma etc are made. While they are very skillful with the compositional aspect of what they do, their correction editing skill is very limited. So no matter how great a job they do with the compositional editing, the lack of matching video from different cameras greatly detracts from the professional appearance of the final result.
Their problem is that very often the white balance, brightness, contrast etc do not match between the cameras. So the problem is more than just optimizing the video from one camera. Is there an easier way to correction edit these parameters in a more automated way so that the video from different cameras match more closely? Right now they do a visual "eyeball" tweak of filters in their editor but this isn't consistent because it is really just eyeball hacking. It is also time consuming.
They use Edius for editing and DVD Workshop for authoring. I suppose they might consider using a different editor if they felt there was a tangible benefit. I think their issue isn't the expense of a new editor but the learning curve with something new. They know Edius like the back of their hand.
Liquid, you can match the historgrams which usually or you can do color correction. I find it best to use the same cameras as well.
Very true but in their case, they don't have this luxury. Usually the second or third camera is a hired free lance videographer's camera. A larger scale operation can control things like this better but the smaller operations are limited in the equipment they can specify.Originally Posted by dun4cheap
It also helps to set the cameras up in one spot pointed at the same thing and set the white balance then. I use this method with 3 cameras and it works well.
Vegas is great for multi cam shoots and post editing. Vegas 8 Pro has a new multi camera mode that allows switches between angles with the click of a mouse. It saves a ton of time for events like that.
Can a VCR be 'mis-aligned' to match tracking of VHS tapes?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 3rd Mar 2012, 15:42 -
video cameras for live event streaming
By kevindougans in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 26th Jan 2012, 12:44 -
3 cameras filming and editing
By obsh in forum Newbie / General discussionsReplies: 4Last Post: 11th Jan 2012, 19:13 -
Editing video recorded with two cameras
By MI6 in forum EditingReplies: 3Last Post: 18th Feb 2011, 20:09 -
Editing video from 2 cameras -problem
By sterankin in forum EditingReplies: 6Last Post: 2nd Aug 2010, 06:01
