Hi - VCD seems to have gone right out of fashion. All I want to do is to make a collection of some of my favourite scenes from VCDs that I made of my daughter when she was a toddler. These were converted onto VCD 7 or 8 years ago from the original video 8.
I'm looking for a program that will allow me to rip short clips of anything up to 3 or 4 minutes and save them im MPG or avi format. But *everything* now is DVD - rippers and converters! I'm looking at pulling apart dat files - or better still an application that reads directly from the VCD movie disk, plays it and allows me to set start and end times for clipping.
Any ideas??
Cheers
Rob
Results 1 to 11 of 11
ISOBuster can, I believe, extract the mpg files from the dat container. Otherwise, try opening the dat files in virtualdubmpeg2 or AVI Demux.
Read my blog here.
VCDGear (freeware).
Use the DAT-> MPG option.
You can edit the resulting MPEG1 using many tools, notably TMPGEnc, which works on MPEG1 in free mode.
The old free version of SVCD2DVDMPG preps these to make a DVD. -
Thanks for the info - I'll check this out.
But does anyone know of something the same as, frinstance, Xilisoft DVD ripper? This reads the movie directly, you can preview a start point and choose "encode from this point". When you hit "stop" it leaves you with a ready-made mpg or avi. Real straightforward! It takes a couple of minutes for a clip and it's done.
Cheers
R -
jagabo's suggestion will work, but I don't recommend using TMPGenc's MPEG Merge/Cut tool. For a sizeable minority of people, this tool will introduce horrible audio sync problems into what it edits. I happen to have a PC that has this problem. In fact, it's specifically what drove me into purchasing MPEGVCR years ago to use as an MPEG editor. The original poster may or may not have sync issues with TMPGenc's Merge/Cut tool, but he should be aware that it is possible and if he is one of those people who does have problems, there's no fix for it. Nobody seems to know why certain systems have problems with it and others (most?) work fine.
MPEGVCR and VideoReDo both can edit MPEG-1 (VCD). Both are "try before you buy". -
But TMPGEnc, if it works for him, is free.
Also worth consideration, if you want to convert segments to AVI, is VirtualDub. -
vcdcutter is perfect for the job-google for it- a free version was available
compare movies, find insertions in one movie relative to another movie
By beroal in forum Newbie / General discussionsReplies: 0Last Post: 19th Jan 2012, 00:11 -
Where to find the best subtitles for movies
By cyberlion in forum SubtitleReplies: 3Last Post: 24th Jul 2010, 13:05 -
Trying to find the DVD ripper with the biggest frame size
By True Colors in forum DVD RippingReplies: 2Last Post: 18th Apr 2010, 23:01 -
I use mac the ripper how do I burn movies in Itune
By hardbeatt in forum MacReplies: 4Last Post: 6th Apr 2008, 19:52 -
Where are some of the best places to find HD DVD Movies ??
By ofield1 in forum Newbie / General discussionsReplies: 0Last Post: 11th Mar 2008, 20:06
