  1. hi,
    i actually use DVD Rebuilder and DVD remake Pro to reauthor my DVD.
    The main problem is than i can't do the same thing with a easyer soft.
    I get 20 DVD recorded with a Sony Handy Cam.
    The menu look like 6 picture by page, each picture is a clip.
    i would like to take some clip from each DVD to make 1 other DVD.
    i explain:
    i use DVD Decrypter to Split the DVD by Chapter.
    once i get all my chapter i choose the best one from each DVD. i put them in the same folder and then i would like to create a DVD with menu that look like the on of the Camera.
    12 picture by page each pict is a clip.
    i use Xilisoft DVD creator 3. it can do exactly what i want.
    Except one thing each page contain only 4 clip because the menu Template get only 3 or 4 clip by page.
    I know it's a not that important but if i have 100 clip. 4 clip by page i will have 25 pages..
    Their is finaly my question:
    Is their any prog that can do it?
    Anyone know a Way to edit the template menu? .menu file or make my owner .menu file?
    In fact i could do it easy with DVD Remake pro, but i would prefer an easyer way to do it. then my dad would be able to do it by itself without spending 4 hours by dvd lol.
    Any information you can give me will be apreciated.
  2. well i'm dumb Nero vision will do it.
    Feb 2004
    Australia
    Bit of learning
    Wax2 + QuEnc (assets generation)
    Vobedit or pgcdemux (demux existing vob's)
    Dvdauthorgui (basic authoring)
    Pgcedit (to correct dvd nav's if not funtioning correctly)
    May want to throw besweet in and convert all audio to ac3, which allows for more video in project
    Pro's: Freeware
    Con's: Need to put a little time into project
    The easy way out
    Ulead video studio 9 se (cheap in ebay)
    Then there's > http://www.dimadsoft.com/menuedit/index.php
  4. Hi, It seem a bit complicated for my dad. I think he don't want to learn he want it easy lol.
    And i already use CCE, DVD Remake and DVD rebuilder for my DVD.
    But i keep them in mind i will maybe need PGC Demux.
    Thank you.
