hi, converting a .flv file to .mov
well it was kinda complicated from the beginning and I fixed the progress.app problem as suggested in another thread
but...
when I do (and I know this problem has been addressed before but in different context)
this happens
Encoding started on Sun Mar 16 19:49:35 PDT 2008
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
[flv @ 0x4701fc]Unsupported audio codec (6)
Seems that stream 1 comes from film source: 1000.00 (1000/1) -> 19.83 (119/6)
Input #0, flv, from '/Users/dominickwong/Desktop/downloads/hello':
Duration: 00:02:23.0, bitrate: N/A
Stream #0.0: Audio: 0x0006, 22050 Hz, mono
Stream #0.1, 19.83 fps(r): Video: flv, yuv420p, 320x240
Codec type mismatch for mapping #0.0 -> #0.0
much thanks in advance
Rumplestiltskin has it right. Ffmpegx expects -- no, demands -- that the video stream precede the audio one. Click on "invert mapping" and that problem should go away. No guarantees that all will be well, of course, but at least you'll have one less thing to track down.
Good luck!
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 17th Sep 2011, 23:06 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 05:44 -
To convert or not to convert a pal dvd
By nls8520 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 01:35
