    Mar 2008
    1.I'm a newb to this so bear with me. I searched around for a solution and just got way too stuck and overwhelmed. I currently have legit backups of many of my dvd movies on my HD ripped with DVDshrink into .ts folders(aud/vid seperate). My main pc is running vista but I also have access to an XP machine if needed. These movies are all about 4gb a movie and taking up way too much space. I have a NAS (network Storage) for my home network and am looking for the easiest way (with quality though) to convert these into something that I can easily stream through my PC's and PS3. I am running Hi-def tv/monitor. Ideally looking for quality without exceeding 1 gb in size per movie. I do have a sweet 5.1 setup so ideally keeping the 5.1 track would also be great. I don't really care about the extras , titles..etc, just the main movie and 5.1. sound.
    2. Simplest way to rip my newer DVDs into compatible format too.
    Any help is much appreciated!...and thanks!
  2. Member Soopafresh's Avatar
    Jan 2004
    Try out AutoGK. It's really easy, and the quality is quite good. You can specify output file size. You can also keep your 5.1 AC3 track.
