I am trying Xilisoft over convertxtodvd to see if conversion quality is better for converting divx to dvd. I also like that I can convert several projects simultaneously. The thing is, there are a lot of settings for bitrate,crop,aspect ratio, etc. I left all of that alone and went with the default settings and ended up with a majorly letter-boxed output video, leading me to believe these settings have to be adjusted. I have looked everywhere for recommended settings but found nothing. Anyone have experience with this software? I just want a nice NTSC conversion of a divx file to VOB to burn and play in my standalone to watch on my widescreen.
I think you will find ConvertX does a better job, but you might need to adjust those settings also. But bitrate determines the size of the video and the quality. The aspect ratio can cause letter boxing. Most videos are 16:9 these days, so you will have some letter boxing when displayed on a 4:3 TV screen. Most of this is basic video settings. You might look to the help files for your program, or go to the programs website and you may find tutorials that would help you understand all the programs settings.
If you want more control of your video, then you have to learn more about it and the programs you want to use. If you want to try a freeware converter, then look into FAVC. But it has even more options.
Xilisoft video converter help
By paul278 in forum Video ConversionReplies: 3Last Post: 18th Sep 2011, 05:12 -
Converting MPEG-2 TS to .mkv Questions (Xilisoft Video Converter)
By 10acjed in forum Video ConversionReplies: 7Last Post: 13th Aug 2011, 15:19 -
By Vman94 in forum Video ConversionReplies: 0Last Post: 12th Jul 2011, 11:35 -
Xilisoft Video converter from mvk to dvd - audio problem
By sychern in forum AudioReplies: 4Last Post: 10th Oct 2008, 02:57 -
WMV to AVI using Xilisoft Mac Video Converter
By BassJunkie in forum MacReplies: 11Last Post: 30th Jul 2008, 02:31
