Hi I have a question on audio with vcd's. When I use smart ripper and the dvd has dts audio. I cant seem to create the AC3 T01 2_0ch 192Kbps 48KHz output that is needed for the audio that tmpeg needs to create the vcd. I'm using dvd2avi. Does anyone have any ideas? Dolby Digital works fine. I had a problem with Cast Away and Pearl Harbor.
the best audio track to use for vcd/svcd creation is dd 2.0. if not available then dd 3/2(5.1) + dolby surround downmix. unless dts is the only track available dont hassle with it
With smart ripper and dvd2avi should there be a chioce for dts or dd becuse I havent seen any out there. Does the dvd only have dts audio or is there an option for dd? thanks
check the stream processing tab in smartripper to identify the audio track (or select a track# + f5 in dvd2avi)
DVD-Audio to Dolby TrueHD or DTS-HD
By greymalkin in forum AudioReplies: 2Last Post: 20th Apr 2011, 11:01 -
adding dts audio stream to DVD folder
By medo_256 in forum Newbie / General discussionsReplies: 56Last Post: 6th Jun 2010, 06:54 -
Is it still DTS audio if its at 448kb/s on a dvd?
By yoda313 in forum AudioReplies: 8Last Post: 7th Sep 2009, 07:06 -
Authoring a DVD with DTS 5.1 Audio
By wanguy2k in forum Authoring (DVD)Replies: 4Last Post: 12th Sep 2007, 17:52 -
How to convert AVI with DTS audio to DVD
By Jean in forum Video ConversionReplies: 6Last Post: 24th Aug 2007, 01:25
