    Dec 2005
    My desktop will not recognize a 2Gb SD card in its build in reader, works fine with 1GB card.
    If I put the same card (2GB) in SD slot in the printer, USB connection to PC, it works fine, usind Vista.
    My Laptop does the exact same thing, reads 1GB but not 2GB using XP.
    Not a huge problem was just wondering...
  2. Member Abbadon's Avatar
    Dec 2003
    Caribbean Sea
    It is a built in reader, some of them come with a read-write limit from the assembly line. Do you know who is the manufacturer?, check it's website for support, bios-firmware upgrade?
    No tengo miedo a la muerte. Solo significa soņar en silencio. Un sueņo que perdura por siempre. ..
