I've posted this problem before but no solution found. I have a dvd from a tv show set that cracked when trying to remove from the case (I eventually had to break the case clips to get it out).
The crack is right at the start of the disk. I cannot retrieve anything from the disk because the dvd drive does not recognize a disk is there (presumably it looks for some basic info at the disk start). The crack is not repairable and all standard software disk doctors don't work because the drive does not "see" the disk. I think it needs some forensic software that's going to tell the dvd drive there is in fact a disk there and to start reading at the first readable information. It may be that only specialized hardware will read the disk. Ideas?
Closed Thread
Bump/Reply to your first topic instead, https://forum.videohelp.com/topic325545.html .
WDTV Live needs to be physically disconnected when it couldn't play a file
By tigerb in forum Newbie / General discussionsReplies: 15Last Post: 29th Sep 2013, 13:50 -
Slightly cracked dvd how to recover. Please!
By boristhespie in forum Authoring (DVD)Replies: 9Last Post: 28th Sep 2010, 23:24 -
Blu-ray BD-R: Would you physically store it in a CaseLogic Wallet pocket?
By rjamesd05 in forum MediaReplies: 0Last Post: 5th Jun 2010, 06:47 -
No sound card on laptop anymore, but there physically is one!
By Rudyard in forum ComputerReplies: 8Last Post: 5th Oct 2009, 19:48 -
How often do you physically clean the inside of your computer?
By yoda313 in forum PollsReplies: 32Last Post: 3rd Sep 2007, 15:00
