In the < $750 range?
Will any capture device capture 720p?
Thanks...
BlackMagic Intensity Pro (with issues ... use forum search)
AJA Xena (different issues)
Hauppauge new card editing issues.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I have been leaning towards the Intensity Pro.
Will it capture in 720p?
Also, I can't seem to find the new Hauppauge device available (even on their site).
The AJA seems VERY similar to the Intensity Pro, but more than twice the price, what's the benefit for going with that? -
KameronK I think edDV ref to new upcoming WinTV HD PVR which not even out which is a Hardware H.264 AVC encoder -
I have noticed that in many cases whenever the discussions evolves around h264 (even mpeg)
that it is advised that these formats are difficult to edit. Perhaps this point should be sort of
refrased somewhat.
I mean. If you are going to edit the h264/mpeg source *directly* or real-time (while inside a
timieline) then is more than likely that editing will not be as accurate or smooth sailing. And the
reason behind that is on account of the decoding and indixing involved while in the real-time type
setup. The index part is sometimes vague in that it can't be properly maintained in many cases.
But, if you create a psuedo (fake) avi (via, VFAPI) or index it with the right tools (ie, dgindex or
dgavc) you shouldn't have any problems editing these h264/mpeg videos. I myself use the VFAPI
codec in the majority of my mpegs. As far as AVC (h264) type videos, I'm new to these and do
not have much experience in terms of optimum handle'age at the moment, though I'm slowly
working in that area.
As far as capturing goes, I've been exploring another avenue. Capturing with the XviD codec,
using I-Frame only and no compression -- well, maybe a tiny bit. I sometimes get a 5.7:1 compresion
ratio, prob comparaitable to DV, but I have not yet completed my notes and things on this. And
I would say that its prob comparitable to my svhs recordings in EP mode or better. Anyhow. I've
been capturing my analog cabletv with this set and my Pinnacle Studio AV/DV card w/ vdub for
the last 3 weeks or so. So far, I am pleased
-vhelp 4593
Advice on a direct capture device from MiniDV cam.
By nomeite in forum Capturing and VCRReplies: 5Last Post: 29th Oct 2010, 09:43 -
Good capture device for me?
By crackedvenom in forum Capturing and VCRReplies: 13Last Post: 5th May 2010, 18:42 -
Recommend one good external capture device
By jranaudo in forum Capturing and VCRReplies: 1Last Post: 8th Jan 2010, 02:35 -
Good capture device for pci-e board?
By ingeborgdot in forum Capturing and VCRReplies: 36Last Post: 7th Nov 2008, 14:17 -
A Good USB Capture Device?
By hech54 in forum Capturing and VCRReplies: 5Last Post: 23rd Dec 2007, 02:23
