I want to plug my camera into my computer, but I don't have a firewire card.
I can't put in a firewire port card in my PCI slot because I don't have a PCI slot free. So, I found this little device.. I don't know what it does:
http://accessories.us.dell.com/sna/productdetail.aspx?sku=A0461337&cs=04&c=us&l=en&dgc...149&lid=644180
Would that work?
I could really use some help, because then my movie production will be delayed!
Thanks,
Joe Tese
Results 1 to 9 of 9
no it needs to be plugged into a firewire port from the computer. think of it as an extension cord with 2 outlets.
maybe you can find a combo card with firewire to replace one of your pci cards.--
I beg your pardon for the giggle that gave me ... was it a garden hose ?Originally Posted by MPTESE
Yank one of the other cards when you need to cap firewire.
http://www.kiva.org/about -
While that would get the video into the computer, it is not the best option. The best possible picture is already on the tape in digital format, that device will cause the camcorder to convert it to analog to output it, then it would get converted back to digital with some inherent loss. A firewire port is the single best option. I'm with EdDV, pull one of the other cards and put the firewire card in to capture, then swap the cards back out. What other cards do you have in there now?Originally Posted by julitomg"Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
Ok thanks guys. That means I'll have to give up my TV tuner, Since I think Video Editing would be more important to me.
Are there any drivers that I need when I buy the firewire card? And if I really wanted to, can I just switch back and forth from my Firewire card to my TV tuner? lol.
Thanks for the replies! -
Windows XP / Vista and 2000 should detect and install drivers for firewire cards.
if the card that you buy does, it will come with it, but all the ones i have installed were found and setup by the winXP installer without any help from me.
swapping cards is fine it won't hurt anything.
newegg.com has some inexpensive ieee1394 firewire cards. iv'e used this one a couple times because it has a port in the back and a 9 pin header to connect to a front panel port if you have one or want to add one.
http://www.newegg.com/Product/Product.aspx?Item=N82E16815124034--
PS3, HDMI Splitter, Video Capture Device or Card, Ambilight, ADVICE!
By NexusSIX1976 in forum Capturing and VCRReplies: 5Last Post: 16th Oct 2011, 21:38 -
Advice on a direct capture device from MiniDV cam.
By nomeite in forum Capturing and VCRReplies: 5Last Post: 29th Oct 2010, 10:43 -
Automatic - Programmed Capture into DV of analog source via Firewire Device
By lasith in forum Capturing and VCRReplies: 5Last Post: 12th Feb 2010, 05:03 -
WTB Video Capture Device, External, Firewire, $250 Budget
By bpatters69 in forum Capturing and VCRReplies: 3Last Post: 22nd Jan 2008, 20:08 -
Which Codec should I capture in for MiniDV over Firewire
By AussieHusky in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 30th Oct 2007, 22:33
