Just got myself a nice dual monitor setup, and was wondering if anyone has some good sites for dual monitor wallpaper?
What We Do In Life, Echoes In Eternity....
What resolution are your combined monitors? I would imagine you could simply take an image that is equal to the sum of the two monitors resolution and it should theoritically be split evenly between the two.
Worth a try.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I have a dual 19" widescreen setup and I gave up searching for wallpapers.
I do my own now, simply select two pictures that match or combine well (same resolution) and with Photoshop make a new file that is equal to the regular height of your resolution and 2 times the width.
Then select it as a wallpaper using the "tile" option.
IE: My monitor's res. is 1440x900, so the JPG is 2880x900.1f U c4n r34d 7h1s, U r34lly n33d 2 g3t l41d!!! -
http://www.wallpaperreview.com/dualmonitor.html offers a list of sites with dual monitor wallpapers, including dual widescreen sites.
e.g.
http://www.socwall.com/browse/index.php?wpCategory=Everything&wpSubcategory=All&wpLimi...&wpQueryType=1
http://www.dualmonitorbackgrounds.com/
http://www.dualscreenwallpaper.com/
http://widewall.blogspot.com/Read my blog here.
Originally Posted by MeDiCo_BrUjODonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Ok so I have (1) 22'- 1680x1050, and (1) 19"- 1280x1024 = 2960 x ? (what would I use the 1050?)
What We Do In Life, Echoes In Eternity.... -
Originally Posted by Denvers Dawgs1f U c4n r34d 7h1s, U r34lly n33d 2 g3t l41d!!!
I use UltraMon -- both desktops have different wallpapers.
having a dual monitor issue....
By lordhutt in forum ComputerReplies: 6Last Post: 17th Aug 2010, 19:21 -
Monitor suggestions for proper Color Correction
By OldMedia in forum RestorationReplies: 1Last Post: 6th May 2010, 22:32 -
Dual Monitor problem
By A Traveller in forum LinuxReplies: 18Last Post: 28th Oct 2009, 14:11 -
Do You Have Any Samsung Monitor Suggestions??
By Ray&Paula in forum ComputerReplies: 11Last Post: 15th Apr 2008, 13:43 -
Any Suggestions For a Good Monitor??
By Ray & Paula in forum ComputerReplies: 20Last Post: 13th Apr 2008, 11:23
