I'm trying to mux an MPEG-2 m2v and an ac3 file together into a Program Stream. I've tried muxing them together using mpeg-vcr, tmpgenc, XMuxer Pro and even muxing to a ts and then converting to a mpg file. But all of them, bar XMuxer, output a file which show as having 0 duration.
The mpg file output from Xmuxer does have the correct prorperties (e.g. duration) when streamed to my PS3 but the audio is out-of-sync with the video and the timeshift setting in Xmuer doesn't seem to do anything.
What causes the outputted mpg file to have a duraiton of 0? Is this something I can fix as the files that output with a duration of 0 don't have any synching issues.
Results 1 to 9 of 9
Have you tried PVA Strumento? i use it to demux and clean up and re-time my Hauppauge MPEG PS streams before authoring. It can also generate a PS.
Nope. I'll give it a try just now.
EDIT: OK, I muxed my m2v and ac3 to a TS file and then loaded them into PVA Strumento to create a PS. It's done 5% and estimates it will take another 5hrs to do the rest
Try to mux the files with ImagoMPEG-Muxer and then create a PES stream with projectx
stars... -
I've tried muxing to a TS using tsMuxer and then converting to a PS (mpg) using HDTVtoMPEG2. ImagoMPEG-Muxer doesn't like the m2v because it's HD (1080p).
Weird???
Muxing with mkvmerge
By sharu006 in forum Video ConversionReplies: 7Last Post: 14th Dec 2012, 11:48 -
Audio Synching issue in Sony Vegas - What is the best way to solve my issue
By pandeyrajiv in forum EditingReplies: 2Last Post: 19th Dec 2010, 22:53 -
K-lite issue then mp4 issue
By Arch3type in forum Software PlayingReplies: 0Last Post: 15th Dec 2010, 10:57 -
Muxing to .mpg
By gameroftheuk in forum Newbie / General discussionsReplies: 2Last Post: 18th Aug 2008, 12:38 -
Muxing Quality
By BassJunkie in forum MacReplies: 2Last Post: 30th Jul 2008, 08:47
