  1. when i go to burn the vcd it tells me that this mpeg may not work in dvd players or something like that and when i click on details it tells me that it's that frame size i'm wondering if i can adjust the frame size using some type of software or do i have to go through the whole process of decrypting and encoding all over again?
    Feb 2002
    Bedworth, England
    try a small file on a rewritable and if it works your OK. in nero you can uncheck the @make compliant@ check box and continue to burn as normal, nero is correct that your player may not support the format. i burn XVCD and it never fails
    happy burning :wink:
