Got it, thanks!
Results 31 to 60 of 109
http://encoding.n3.net <-- for all your DVD and CD backup needs!
finally have the abit p35e chipset up and o/c'd, stock voltage and fan cooled, runs 39c idle 58c 100% load.
quad q6600 kentfield 2.40 @ 3.0
9 x 333
fsb 1332
dram 5-5-5-13 2t @ 333 ddr2
winXp w/sp2
---------- RUN1PASS1.LOG
encoded 1442 frames, 60.84 fps, 3904.67 kb/s
---------- RUN2PASS1.LOG
encoded 1442 frames, 60.72 fps, 3904.67 kb/s
---------- RUN3PASS1.LOG
encoded 1442 frames, 60.87 fps, 3904.67 kb/s
---------- RUN4PASS1.LOG
encoded 1442 frames, 60.80 fps, 3904.67 kb/s
---------- RUN1PASS2.LOG
encoded 1442 frames, 16.88 fps, 3952.97 kb/s
---------- RUN2PASS2.LOG
encoded 1442 frames, 16.86 fps, 3952.97 kb/s
---------- RUN3PASS2.LOG
encoded 1442 frames, 16.90 fps, 3952.97 kb/s
---------- RUN4PASS2.LOG
encoded 1442 frames, 16.84 fps, 3952.97 kb/s--
Got it, thanks
http://encoding.n3.net <-- for all your DVD and CD backup needs! -
grayski - do you want numbers for bigger o/c's that i wouldn't run all the time? 3.6 is stable and i've got it to boot at up to 4.5 for a couple hours, but there's too much heat to keep it running too long.
We have several 1600 running @ 9x400 but if you wanna give it a go, I'll add your results as well.
nice new report graysky - same 6600 @ 3.0 i'll try higher later.
x264 HD BENCHMARK RESULTS
Please copy/paste everything below the line into the forum post to report your data
Results for x264.exe v0.58.747
encoded 1442 frames, 60.76 fps, 3904.62 kb/s
encoded 1442 frames, 60.40 fps, 3904.62 kb/s
encoded 1442 frames, 60.44 fps, 3904.62 kb/s
encoded 1442 frames, 16.84 fps, 3953.18 kb/s
encoded 1442 frames, 16.78 fps, 3953.18 kb/s
encoded 1442 frames, 16.81 fps, 3953.18 kb/s
encoded 1442 frames, 16.80 fps, 3953.18 kb/s
Results for x264.exe v0.59.819M
encoded 1442 frames, 64.99 fps, 3888.27 kb/s
encoded 1442 frames, 65.04 fps, 3887.13 kb/s
encoded 1442 frames, 65.13 fps, 3887.79 kb/s
encoded 1442 frames, 64.95 fps, 3888.99 kb/s
encoded 1442 frames, 18.79 fps, 3963.26 kb/s
encoded 1442 frames, 18.83 fps, 3963.32 kb/s
encoded 1442 frames, 18.77 fps, 3963.24 kb/s
encoded 1442 frames, 18.80 fps, 3962.89 kb/s
System Details
Name Intel Core 2 Quad Q6600
Codename Kentsfield
Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Core Stepping G0
Technology 65 nm
Stock frequency 2400 MHz
Core Speed 2997.2 MHz (9.0 x 333.0 MHz)
FID range 6.0x - 9.0x
Northbridge Intel P35/G33/G31 rev. A2
Southbridge Intel 82801IB (ICH9) rev. 02
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Cycle Time (tRAS) 13
Command Rate 2T
Memory Frequency 333.0 MHz (1:1)
Memory Type DDR2
Memory Size 2048 MBytes
Channels Dual (Symmetric)
Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
max VID 1.288 V
Voltage sensor 0 1.22 Volts [0x99] (CPU VCORE)
Number of processors 1
Number of threads 4
Number of threads 4 (max 4)
L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
Package Socket 775 LGA (platform ID = 4h)
Temperature sensor 0 36°C (96°F) [0x24] (SYSTIN)
Temperature sensor 1 57°C (134°F) [0x72] (CPUTIN)
Temperature sensor 2 71°C (158°F) [0x8D] (AUXTIN)
Temperature sensor 0 56°C (132°F) [0x2C] (core #0)
Temperature sensor 2 51°C (123°F) [0x31] (core #2)
Temperature sensor 3 54°C (129°F) [0x2E] (core #3)
Temperature sensor 1 55°C (130°F) [0x2D] (core #1)
Temperature sensor 0 60°C (139°F) [0x3C] (GPU Core)
edit - it's the same as your other 3.6ghz 6600's, i tried for 4.5ghz @ 9x500 but it crashes windows too quickly to complete the test.--
@aedipuss - got it, thanks! 9x500 for a quad is insane
Q6600 @ 2.40GHz
encoded 1442 frames, 49.30 fps, 3905.42 kb/s
encoded 1442 frames, 49.40 fps, 3905.42 kb/s
encoded 1442 frames, 49.33 fps, 3905.42 kb/s
encoded 1442 frames, 49.49 fps, 3905.42 kb/s
encoded 1442 frames, 13.30 fps, 3952.85 kb/s
encoded 1442 frames, 13.33 fps, 3952.85 kb/s
encoded 1442 frames, 13.31 fps, 3952.85 kb/s
encoded 1442 frames, 53.16 fps, 3889.29 kb/s
encoded 1442 frames, 53.16 fps, 3889.21 kb/s
encoded 1442 frames, 53.01 fps, 3889.35 kb/s
encoded 1442 frames, 53.07 fps, 3889.36 kb/s
encoded 1442 frames, 14.86 fps, 3962.75 kb/s
encoded 1442 frames, 14.86 fps, 3962.81 kb/s
encoded 1442 frames, 14.87 fps, 3962.67 kb/s
encoded 1442 frames, 14.89 fps, 3962.47 kb/s
System Details
Codename Kentsfield
Core Stepping G0
Technology 65 nm
Core Speed 2397.6 MHz (9.0 x 266.4 MHz)
Northbridge Intel P965/G965 rev. C2
Southbridge Intel 82801HH (ICH8DH) rev. 02
Memory Type DDR2
Memory Size 2022 MBytes
Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
max VID 1.325 V
Number of threads 4
Temperature sensor 0 47°C (116°F) [0x35] (core #0)
Temperature sensor 2 45°C (112°F) [0x37] (core #2)
Temperature sensor 1 49°C (120°F) [0x33] (core #1)
Temperature sensor 3 48°C (118°F) [0x34] (core #3) -
@darrellS - thanks for the data... can you gimme your mem timings and what speed are you running them at?
This is where I'm getting confused.
I have two sticks of G.Skill 800 memory
Cas Latency: 5
Timing: 5-5-5-15
Voltage: 1.8V - 2.0V
(recommended for this board)
Intel reads it as 800Mhz but CPU-Z reads it as 400Mhz
DIMM #1
General
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) G.Skill (7F7F7F7FCD000000)
Size 1024 MBytes
Max bandwidth PC2-6400 (400 MHz)
Part number F2-6400CL5-1GBNQ
Attributes
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
Timings table
Frequency (MHz) 266 400
CAS# 4.0 5.0
RAS# to CAS# delay 4 5
RAS# Precharge 4 5
TRAS 10 15
TRC 14 21
DIMM #2
General
Memory type DDR2
Size 1024 MBytes
Attributes
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
Timings table
CAS# 4.0 5.0
RAS# Precharge 4 5
TRAS 10 15
TRC 14 21
Either CPU-Z is reading it wrong or Newegg sent me the wrong memory. -
thanks, since they're DDR2, CPU-Z's numbers need to be doubled. That's just the way it displays them so no worries there. I'll add your results to the database and update either tonight or tomorrow.
Thanks!
My brother got the OK to spend his tax relief check on a new motherboard for me in exchange for my Intel board and Pentium D chip so I'll be updating again in a couple of weeks. -
graysky - in the excel report on line 84 you list the cpu as an fx-60 "kentsfield" i think it should be a q6600 as it looks like some of the results i posted for you.
Thanks for catching that dude, I'll fix it.
I finally got my Gigabyte up and running. Had problems getting the memory straightened out, CPU was only running at 2.1Ghz.
Q6600 @ 2.66Ghz 8X333
encoded 1442 frames, 55.10 fps, 3905.42 kb/s
encoded 1442 frames, 56.27 fps, 3905.42 kb/s
encoded 1442 frames, 56.41 fps, 3905.42 kb/s
encoded 1442 frames, 56.07 fps, 3905.42 kb/s
encoded 1442 frames, 15.13 fps, 3952.85 kb/s
encoded 1442 frames, 15.15 fps, 3952.85 kb/s
encoded 1442 frames, 15.14 fps, 3952.85 kb/s
encoded 1442 frames, 15.12 fps, 3952.85 kb/s
encoded 1442 frames, 60.40 fps, 3880.47 kb/s
encoded 1442 frames, 60.80 fps, 3884.58 kb/s
encoded 1442 frames, 60.80 fps, 3881.18 kb/s
encoded 1442 frames, 60.52 fps, 3881.65 kb/s
encoded 1442 frames, 16.95 fps, 3963.12 kb/s
encoded 1442 frames, 16.95 fps, 3962.98 kb/s
encoded 1442 frames, 16.95 fps, 3962.95 kb/s
encoded 1442 frames, 16.97 fps, 3963.00 kb/s
System Details
Codename Kentsfield
Core Stepping G0
Technology 65 nm
Core Speed 2664.1 MHz (8.0 x 333.0 MHz)
Southbridge Intel 82801IR (ICH9R) rev. 02
CAS# 5.0
RAS# to CAS# 7
RAS# Precharge 7
Cycle Time (tRAS) 20
Command Rate 2T
Memory Frequency 532.8 MHz (5:8)
Memory Type DDR2
max VID 1.325 V
Voltage sensor 0 1.30 Volts [0x51] (CPU VCORE)
Number of threads 4
Temperature sensor 0 46°C (114°F) [0x2E] (TMPIN0)
Temperature sensor 1 48°C (118°F) [0x30] (TMPIN1)
Temperature sensor 0 52°C (125°F) [0x30] (core #0)
Temperature sensor 3 57°C (134°F) [0x2B] (core #3)
Temperature sensor 2 52°C (125°F) [0x30] (core #2)
Temperature sensor 0 51°C (123°F) [0x33] (GPU Core) -
@DarrellS - got it, thanks!
Q6600 @ 3.2Ghz 8X400
encoded 1442 frames, 64.67 fps, 3904.67 kb/s
encoded 1442 frames, 65.64 fps, 3904.67 kb/s
encoded 1442 frames, 65.73 fps, 3904.67 kb/s
encoded 1442 frames, 65.69 fps, 3904.67 kb/s
encoded 1442 frames, 18.04 fps, 3952.97 kb/s
encoded 1442 frames, 18.05 fps, 3952.97 kb/s
encoded 1442 frames, 18.01 fps, 3952.97 kb/s
encoded 1442 frames, 70.56 fps, 3889.34 kb/s
encoded 1442 frames, 70.40 fps, 3888.63 kb/s
encoded 1442 frames, 70.34 fps, 3888.64 kb/s
encoded 1442 frames, 70.72 fps, 3889.38 kb/s
encoded 1442 frames, 20.19 fps, 3962.89 kb/s
encoded 1442 frames, 20.19 fps, 3962.67 kb/s
encoded 1442 frames, 20.20 fps, 3962.64 kb/s
encoded 1442 frames, 20.19 fps, 3962.87 kb/s
System Details
Codename Kentsfield
Core Stepping G0
Technology 65 nm
Core Speed 3200.0 MHz (8.0 x 400.0 MHz)
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Cycle Time (tRAS) 15
Command Rate 2T
Memory Frequency 400.0 MHz (1:1)
Memory Type DDR2
max VID 1.325 V
Number of threads 4
Temperature sensor 0 43°C (109°F) [0x2B] (TMPIN0)
Temperature sensor 1 49°C (120°F) [0x31] (TMPIN1)
Temperature sensor 1 54°C (129°F) [0x2E] (core #1)
Temperature sensor 0 44°C (111°F) [0x2C] (GPU Core) -
now it's cooking darrells
no more over speed ram and the timings look much better.
cool man, got it. If you have DDR2-1066 memory, you can run them up @ a 4:5 divider @ your 8x400 and hit 1,000 MHz for a slight gain.
I wasn't sure what to do with the DRAM multiplier since there was no 1 setting. I just changed the host frequency to 400 and changed the memory multiplier to 2.0 since I had seen that spec in an overclockers forum. First, I tried to set it to Auto since I didn't see a 1.0 and the system wouldn't start up. It was caught in a loop trying to start. First I set it back to default settings then decided to try the settings that I assumed would work and it fired up.
I googled a lot of different overclockers sites in the last couple of days but couldn't find anything for overclocking this board for beginners so decided to use the G.SKILL specs with the 400 CPU frequency and the 2.00 multiplier. I didn't want to try and figure out memory and voltage settings since all that is way over my head.
I'm kinda worried about how long the CPU will last running at this speed. If I can get four or five years, I'll be happy. It isn't running hot with the Hyper 212 cooler. Around 36* idle and looks like the highest it got under load was 57*.
Graysky, how do I do that? Here is how I have my BIOS settings now.
Do I change the System Memory Multiplier (SPD) to 4.5?Code:For FSB 400 Mhz CPU Robust Graphics Booster........[Auto] CPU Clock......................[ 8 X] CPU Host Clock Control.........[Enabled] CPU Host Frequency(Mhz)........[400] PCI Express Frequency(Mhz).....[Auto] C.I.A.2........................[Disabled] System Memory Multiplier.(SPD).[2.0] Memory Frequency (Mhz) 800 800 High Speed DRAM DLL Settings...[Option 1] Performance Enhance............[Standard] DRAM Timing Selectable...(SPD).[Manual] CAS Latency Time.............5 [5] DRAM RAS# to CAS# Delay......5 [5] DRAM RAS# Precharge..........5 [5] Precharge Delay(tRAS).......15 [15] ACT to ACT Delay(tRRD).......3 [Auto] Rank Write to Read Delay.....3 [Auto] Write to Precharge Delay.....6 [Auto] Refresh to ACT Delay........42 [Auto] Read to Precharge Delay......3 [Auto] tRD..........................3 [Auto] tRD Phase Adjustment.........0 [Auto] *****System Voltage Not Optimized***** System Voltage Control.........[Manual] DDR2/DDR3 Overvoltage Control..[+0.3V] PCI-E Overvoltage Control......[Normal] FSB Overvoltage Control........[Normal] {G} MCH Overvoltage Control....[Normal] CPU Voltage Control............[Normal] Normal CPU Vcore.............. .1.32500V -
@DarrellS - hmm... I dunno, on my board there is an option for both the MB strap and the divider. Which board do you have?
Went back into BIOS to see what I could do and noticed that my memory frequency had changed to 800 800. I edited the above post to show the change.
Tried setting to 4.0= and PC wouldn't start with three loud beeps. Changed back to 2.0 at 800Mhz. I'll try googling some more and see if I can't find the answer to the magic number. -
Seems like the only way I can get it to run stable is with the above settings so I'm gonna leave them as they are unless someone with the same board and memory can give me some pointers.
CPU-Z has my FSB
RAM at 1:1 with the 2.00 system Memory multiplier.
@darrells - I dunno about that particular board... see if there's an option to manually select the fsb strap in the bios if you want to run a non 1:1 divider. I wonder if 2.00 = 1:1 and 4.00 = 1:2 or something like that... can you use fractions?
encoded 1442 frames, 48.07 fps, 3905.23 kb/s
encoded 1442 frames, 47.74 fps, 3905.23 kb/s
encoded 1442 frames, 48.04 fps, 3905.23 kb/s
encoded 1442 frames, 47.50 fps, 3905.23 kb/s
encoded 1442 frames, 13.43 fps, 3952.94 kb/s
encoded 1442 frames, 13.42 fps, 3952.94 kb/s
encoded 1442 frames, 51.70 fps, 3889.19 kb/s
encoded 1442 frames, 51.96 fps, 3889.53 kb/s
encoded 1442 frames, 52.08 fps, 3891.41 kb/s
encoded 1442 frames, 51.79 fps, 3887.57 kb/s
encoded 1442 frames, 15.13 fps, 3962.81 kb/s
encoded 1442 frames, 15.13 fps, 3962.57 kb/s
encoded 1442 frames, 15.14 fps, 3962.86 kb/s
encoded 1442 frames, 15.16 fps, 3963.70 kb/s
System Details
Codename Kentsfield
Core Stepping G0
Technology 65 nm
Core Speed 2405.5 MHz (9.0 x 267.3 MHz)
Northbridge Intel G35 rev. 03
CAS# 6.0
RAS# to CAS# 6
RAS# Precharge 6
Cycle Time (tRAS) 18
Command Rate 2T
Memory Frequency 400.9 MHz (2:3)
Memory Type DDR2
Memory Size 1016 MBytes
Channels Single
Windows Version Microsoft Windows XP Media Center Edition Professional Service Pack 2 (Build 2600)
max VID 1.250 V
Voltage sensor 0 1.14 Volts [0x8F] (CPU VCORE)
Number of threads 4
Temperature sensor 0 37∞C (98∞F) [0x25] (SYSTIN)
Temperature sensor 1 51∞C (123∞F) [0x66] (CPUTIN)
Temperature sensor 0 67∞C (152∞F) [0x21] (core #0)
Temperature sensor 1 61∞C (141∞F) [0x27] (core #1)
Temperature sensor 2 58∞C (136∞F) [0x2A] (core #2)
Temperature sensor 3 59∞C (138∞F) [0x29] (core #3) -
Thanks man, got it!
MB: Asus M3A
CPU: AMD Phenom 9550
Ram: DDR2 800Mhz 6400
Gpu: Geforce 8400 GS
OS: XP Pro 32-bit SP3
encoded 1442 frames, 49.67 fps, 3889.11 kb/s
encoded 1442 frames, 49.56 fps, 3889.38 kb/s
encoded 1442 frames, 49.64 fps, 3886.39 kb/s
encoded 1442 frames, 49.94 fps, 3889.36 kb/s
encoded 1442 frames, 12.58 fps, 3962.79 kb/s
encoded 1442 frames, 12.56 fps, 3962.44 kb/s
encoded 1442 frames, 12.59 fps, 3963.41 kb/s
encoded 1442 frames, 12.59 fps, 3962.44 kb/s -
encoded 1442 frames, 66.47 fps, 3904.94 kb/s
encoded 1442 frames, 67.04 fps, 3904.94 kb/s
encoded 1442 frames, 67.10 fps, 3904.94 kb/s
encoded 1442 frames, 66.09 fps, 3904.94 kb/s
encoded 1442 frames, 32.46 fps, 3974.08 kb/s
encoded 1442 frames, 32.53 fps, 3974.08 kb/s
encoded 1442 frames, 32.52 fps, 3974.08 kb/s
encoded 1442 frames, 32.50 fps, 3974.08 kb/s
encoded 1442 frames, 67.85 fps, 3895.06 kb/s
encoded 1442 frames, 66.53 fps, 3896.09 kb/s
encoded 1442 frames, 66.38 fps, 3895.56 kb/s
encoded 1442 frames, 67.65 fps, 3894.46 kb/s
encoded 1442 frames, 36.40 fps, 3981.30 kb/s
encoded 1442 frames, 36.39 fps, 3981.05 kb/s
encoded 1442 frames, 36.49 fps, 3981.30 kb/s
encoded 1442 frames, 36.49 fps, 3981.53 kb/s
System Details
Name Intel Xeon E5450
Codename Harpertown
Codename Harpertown
Specification Intel(R) Xeon(R) CPU E5440 @ 2.83GHz
Core Stepping C0
Core Stepping C0
Technology 45 nm
Technology 45 nm
Stock frequency 2833 MHz
Core Speed 2826.3 MHz (8.5 x 332.5 MHz)
FID range 6.0x - 8.5x
Northbridge Intel 5000X rev. 12
Southbridge Intel 6321ESB rev. 09
Memory Frequency 332.5 MHz (1:1)
Memory Type FB-DDR2
Memory Size 16380 MBytes
Windows Version Microsoft Windows Server 2003 Standard Edition Service Pack 2 (Build 3790)
max VID 1.225 V
max VID 1.225 V
Number of processors 2
Number of threads 8
L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
Package Socket 771 LGA (platform ID = 6h)
Temperature sensor 0 65°C (148°F) [0x28] (core #0)
Temperature sensor 1 61°C (141°F) [0x2C] (core #1)
Temperature sensor 2 64°C (147°F) [0x29] (core #2)
Temperature sensor 3 63°C (145°F) [0x2A] (core #3)
Temperature sensor 0 71°C (159°F) [0x22] (core #0)
Temperature sensor 1 66°C (150°F) [0x27] (core #1)
Temperature sensor 2 70°C (157°F) [0x23] (core #2)
Temperature sensor 3 71°C (159°F) [0x22] (core #3) -
encoded 1442 frames, 53.97 fps, 3905.42 kb/s
encoded 1442 frames, 54.54 fps, 3905.42 kb/s
encoded 1442 frames, 52.32 fps, 3905.42 kb/s
encoded 1442 frames, 52.83 fps, 3905.42 kb/s
encoded 1442 frames, 15.21 fps, 3952.85 kb/s
encoded 1442 frames, 15.27 fps, 3952.85 kb/s
encoded 1442 frames, 15.18 fps, 3952.85 kb/s
encoded 1442 frames, 58.78 fps, 3889.29 kb/s
encoded 1442 frames, 56.93 fps, 3888.93 kb/s
encoded 1442 frames, 58.26 fps, 3889.38 kb/s
encoded 1442 frames, 57.54 fps, 3886.51 kb/s
encoded 1442 frames, 17.01 fps, 3962.83 kb/s
encoded 1442 frames, 17.26 fps, 3962.56 kb/s
encoded 1442 frames, 16.95 fps, 3962.87 kb/s
encoded 1442 frames, 15.52 fps, 3963.23 kb/s
System Details
Name Intel Core 2 Quad Q9450
Codename Yorkfield
Specification Intel(R) Core(TM)2 Quad CPU Q9450 @ 2.66GHz
Core Stepping C1
Technology 45 nm
Stock frequency 2666 MHz
Core Speed 2666.8 MHz (8.0 x 333.3 MHz)
FID range 6.0x - 8.0x
Northbridge Intel P45 rev. A3
Southbridge Intel 82801JR (ICH10R) rev. 00
CAS# 5.0
RAS# to CAS# 5
RAS# Precharge 5
Command Rate 2T
Memory Frequency 400.0 MHz (5:6)
Memory Type DDR3
max VID 1.250 V
Voltage sensor 0 1.18 Volts [0x4A] (CPU VCORE)
Number of threads 4
Temperature sensor 0 45°C (112°F) [0x2D] (TMPIN0)
Temperature sensor 1 58°C (136°F) [0x3A] (TMPIN1)
Temperature sensor 0 79°C (174°F) [0x1A] (core #0)
Temperature sensor 3 77°C (170°F) [0x1C] (core #3)
Temperature sensor 2 77°C (170°F) [0x1C] (core #2)
Temperature sensor 1 76°C (168°F) [0x1D] (core #1)
x264 Encoding Help
By Trismegistus in forum Video ConversionReplies: 14Last Post: 28th Apr 2012, 09:55 -
Follow-up: x264 CPU usage--threads vs. instances
By Calidore in forum DVD RippingReplies: 26Last Post: 12th Feb 2010, 20:24 -
Best CPU chart for x264 HD Video Encoding Performance
By INFRATOM in forum Media Center PC / MediaCentersReplies: 1Last Post: 2nd Feb 2009, 23:55 -
x264 CPU benchmark - Compare different CPUs encoding the same file
By graysky in forum ComputerReplies: 108Last Post: 16th Dec 2008, 02:19 -
x264/720p CPU requirements
By RB4891 in forum Media Center PC / MediaCentersReplies: 3Last Post: 15th Jun 2007, 08:31
