I have 30 JPG images taken from the same view point at different times. The images are named IMAGE-001.JPG, IMAGE-002.JPG, IMAGE-003.JPG,,, IMAGE-030.JPG
How can I join these images to create an AVI file? I have VirtualDubMod and AVISYNTH, but do not know the script or command to join them. Or do I need to use something else?
Thank you.
Results 1 to 10 of 10
http://avisynth.org.ru/docs/english/
And there should be a copy of the AVS documentation
sleeping somewhere on your hard drive.
VirtualDubMod can open them directly. File -> Open Video File, then select the first image. It will automatically append seqencially numbered images.
Midzuki, Do you know the AVISynth script to load a range of images into one continuos file?
Jagabo, VirtualMod only loads two images and then stops. I appreciate the suggestion. Is there something else I should try?
NOTE: All the JPG images are the exact same dimension (48x60 pixels) and are the only thing in the directory (Windows-XP). -
That's weird, VirtualDubMod works for me as jagabo suggested
Avidemux can load images too, but you have to manually append them. If you have 30 it's not that bad i guess. You might want to change the frame rate from 30 to something else. -
Then there is something wrong. Is the third file numbered sequentially? Does it have the same number of digits? Try starting with the fourth image. Does it load all the rest? I've used VirtualDubMod like this many times before.Originally Posted by forensic
AviSynth's image reading functions are ImageReader() and ImageSource(). See the documentation for their useage details. In your case it will be something like:
ImageSource("C:\Path to files\IMAGE-%03d.JPG", 1, 30, 23.9076)
The %03d means the file names will be 3 digit (the 3) decimal (the d) numbers with leading zeros (the 0).
If VirtualDubMod had a problem with the sequence AviSynth probably will too. -
That should load:Originally Posted by forensic
Each frame should appear once, and the frame rate should be 23.976 fps. Try adding info=true to the command to see the filenames (stamped onto each frame). The documentation states that black frames are added if a file isn't found. I verified this and also found that a black frame was substituted if a frame of another size was found.
ImageSource("C:\TEST\Untitled-%03d.jpg", 100, 103, 23.9076, info=true)
What are you using to view the results? If you aren't already, use VirtualDubMod so you can step through the images frame by frame. -
Problem solved.
I forgot the classic Windows commandment "When wierd things happen...reboot"
Thank you
Blending Images(jpg) together
By Soixante in forum EditingReplies: 11Last Post: 24th Jan 2011, 19:28 -
Trying to join jpg converted to avi with mp3 and upload to youtube.
By Yosho in forum EditingReplies: 2Last Post: 24th Apr 2010, 21:02 -
By bryankendall in forum Newbie / General discussionsReplies: 3Last Post: 29th Nov 2008, 16:13 -
converting JPG images to VIDEO / MOVIE
By pglenn in forum Video ConversionReplies: 4Last Post: 18th Apr 2008, 01:03 -
How to insert a jpg file in the middle of an avi file?
By pmolson in forum Authoring (DVD)Replies: 7Last Post: 2nd Jul 2007, 03:26
