hello, like i said already in another topic
i got problems with a .mp4 movie: the sound comes too early, around a half second before the picture
is there a program to set the sound right to sync, which does NOTHING else, not converting to any other format or anything
just set the sound -/+500 ms, and for MP4 files
i tried avidemux, but it didnt work
EDIT: procedure seems to only work with mpeg4 in AVI. Sorry!
You can try Avanti which uses FFmpeg that has a TS (time stamp offset) option.
https://forum.videohelp.com/topic343287.html
You must use a FFmpeg version SVN-r12134 or higher because there were
muxing problems in previous versions.
1. First demux the mp4 using the UNI_DEMUX_SETUP template.
2. Then load the mp4 with video only on source 1 and the audio on source 2.
3. Then use UNI_MUX_SETUP template and set the TS offset field to -500 ms
... to mux it back to a mp4 (setting PS or default should give a mp4 container).
This option shifts the video not the audio, that's why you have to set -500
Chris. -
thanks a lot
i seem to have it worked b4 i saw your answer by another way though
(conerting to avi, then muxing, then converting to mp4 with ps3 converter)
mp4 out of Sync
By brassplyer in forum Video ConversionReplies: 5Last Post: 10th Aug 2009, 18:40 -
MP4 to MP4 out-of-sync
By Iwan2learn in forum Video ConversionReplies: 2Last Post: 16th May 2009, 23:43 -
Mp4 sync issue...
By sonnenkind in forum Video ConversionReplies: 8Last Post: 24th Feb 2009, 23:27 -
help guys. out of sync mp4.
By tryvora in forum Video ConversionReplies: 2Last Post: 26th Dec 2008, 11:54 -
Out of sync on mp4 player
By SonicFusion in forum Newbie / General discussionsReplies: 1Last Post: 16th May 2007, 06:38
