Hi, i appologize if i post this in the wrong spot but I have taped something off the tv which is 11.4 gigs... When i go to take out the commercials it only brings it down to about 9.4 gigs... I was just wondering if there was a program out there to make the original file smaller say to 10 gigs or even 9 so that when i take out the commercials i can fit it onto a double layer dvd? Thanks for your help greatly appreciated.
A quick and easy way would be to use DVD Shrink. Change the output size under Edit > Preferences. Choose Custom and temporarily change the size to about 8050MB or so. To retain more quality, make sure to Perform Deep Analysis & use Quality Settings (my preference is Maximum Smoothness), but that's just me.
Burn with ImgBurn onto preferably a Verbatim DVD+R DL disc.-The Mang -
its looking for the imagne file or the disc... The file just a mpg file on my computer havn't been able to shrink it yet because i havnt been able to burn it to a dvd
Best would probably be to re-encode it. You can use a bitrate calculator to set the output size and bitrate.
Or you could try a program like ReJig, which does similar to DVDShrink, but is made for MPEG files. It can transcode the file to a smaller size. Works well enough if you need just a little reduction. I'm not sure how well it will perform reducing by 1GB. But it's worth a try.
And welcome to our forums.
So let me see if i understand this... Dvdshink will be able to take out the commericals and make the dvd smaller. Because i have a program called TMPGEoc DVD Author that takes out the commericals but doesn't make it smaller then 9 gigs
DVD Shrink's main purpose is to "shrink" DVD compliant files; not really designed to remove commercials. It sort of can, but it is not frame precise and every edit you make would be its own title (non-consecutive/short pauses in between titles). I have not used TMPGenc DVD Author, but it seems a little strange since this is what it says on the authors web page: The Smart Rendering technology of TMPGEnc DVD Author 3 with DivX® Authoring allows you to transcode (shrink) your projects to fit onto single or dual-layer DVD's, or even CD-R and CD-RW's (transcoding to CD for DivX® projects only) Maybe someone familiar with the application can help you make a needed setting to "shrink" it down to dual layer size.Originally Posted by MKoivuFan
If you have successfully removed the commercials and have authored the mpeg to DVD files, you should then be able to use DVD Shrink or any other transcoder or encoder to bring it down in size. A better alternative to DVD Shrink is DVD Rebuilder in conjunction w/ HC Encoder (included in DVD-RB installation) which will typically give you better results. Try out the free version first. There is also a pro version which has more features.-The Mang
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 17:13 -
Burning Double Layer DVD with no Layer Break.
By aspen matthews in forum Authoring (DVD)Replies: 12Last Post: 24th Oct 2009, 14:26 -
DVD+R9 Double Layer first burn: problems with layer switch
By Edmund Blackadder in forum DVD RippingReplies: 400Last Post: 4th Oct 2009, 12:27 -
Smaller file size after Video Capture (help)
By convoy71 in forum Capturing and VCRReplies: 4Last Post: 4th Apr 2009, 18:05 -
How to burn 8.3G iso movie file to dvd double layer disc?
By ibearzz in forum DVD RippingReplies: 12Last Post: 21st Oct 2007, 20:47
