Here’s my situation:
My 37” Ölevia has but one HDMI input.
I have my COMCAST HD box connected via HDMI and my upconverting DVD player-recorder via component. I found this to be optimal, as the drop in PQ from connecting my HD box over component was unacceptable. As I have been unable to find a hack to get my LG RC797T to upconvert over component, when I am going to be watching DVDs at a higher rez than 480p, I pull out the COMCAST HDMI and plug in the DVD’s HDMI, and reset the player’s resolution.
My concern is that I may somehow damage the HDMI input to my Ölevia by continuing to do this.
Is there some sort of male-female extension I can use for the constant plugging and unplugging of HDMI cables, so that #1 it is easier to swap the HDMIs, and #2 should it get damaged, it would be easier and less expensive to replace.
Or do I really need to invest in a $$$ HDMI switcher (and a third HDMI cable) ?
You can get 2 port HDMI switches for about $20 and another HDMI cable for $10.
I found this:
http://www.radioshack.com/product/index.jsp?productId=2989800&cp=&sr=1&origkw=hdmi+mal...entPage=search
Will this gizmo degrade the connection in any way ? -
Probably not, but a switch would be the better option.
A few switches: http://www.monoprice.com/products/subdepartment.asp?c_id=101&cp_id=10110 -
I have an LG Plasma with only one HDMI input. Been using it for my HD sat receiver, but wanted to add HDMI DVD and later possibly a media PC. I bought a Vivanco auto-switch with 4 HDMI inputs, and it works a treat. Well worth the investment, unless you are considering upgrading the TV anytime soon (most new plasmas/LCDs have at least two HDMI inputs).
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 16:20 -
Connecting DVR (HDMI) to DVD recorder (non HDMI), on HDTV...
By SOHkat in forum DVD & Blu-ray RecordersReplies: 2Last Post: 19th Oct 2010, 13:50 -
HDMI splitter vs switcher decision.
By itg33k in forum DVB / IPTVReplies: 4Last Post: 1st Dec 2009, 13:02 -
xbox 360 hdmi problem (hdmi works on other hdtvs but not mine
By dmiklo in forum Capturing and VCRReplies: 0Last Post: 23rd Sep 2009, 16:51 -
multimedia player connection via hdmi but monitor doesnt have hdmi slot
By ozy666 in forum DVB / IPTVReplies: 1Last Post: 25th Apr 2009, 09:40
